I seem to recall someone having a problem in fitting a Corsa pas to an escort, the issue being interfering with the masters on a bias box ? Just gone through some old old threads on another forum with ref to the mk2 mania kits and it would appear if you use one with original ign switch fitted it lowers the motor causing the  problems. Just a bit of more useless info
Going to fit power steering to the Sport Col?
No won’t need it on near std wheels, only got it fitted on the Anglebox.
