flyingbanana Posted March 5, 2007 Report Posted March 5, 2007 what engine paint do you use that does not flake off ....has so far every one ive used flakes off...last one i used was Foliatec Engine Paint Kit £25 and its flaked
flyingbanana Posted March 5, 2007 Author Report Posted March 5, 2007 i suppose that B&Q stuff....does it stand up to high temps
Fiesta Steve Posted March 5, 2007 Report Posted March 5, 2007 Prep is the key to get it to stick on. Mines been on two years and not a single piece has flaked. I used Carplan.
flyingbanana Posted March 5, 2007 Author Report Posted March 5, 2007 or do you think i should try and polish the block up.....this is my thermostat cover i did
GT_Jim Posted March 5, 2007 Report Posted March 5, 2007 or do you think i should try and polish the block up.....this is my thermostat cover i did way to much effort and it will always get dirty drop some hamerite on it
Capripete Posted March 5, 2007 Report Posted March 5, 2007 I used rattle cans to do the rocker cover on mine, no problems with flaking at all. Just make sure you get all the oily crud and any rust off.
Jay_harrier Posted March 5, 2007 Report Posted March 5, 2007 Get the old stuff off with paint stripper or a wire brush bit in an electric drill, then get some decent heat/oil/fuel resistant paint and splash it on. I think Frost do some & in genuine Ford colours too I've got a block that's had the same coat of paint for 7 years & it's only now that I'm re-doing it.
Chris! Posted March 5, 2007 Report Posted March 5, 2007 i use hammerite Check my thermostat cover thingy
flyingbanana Posted March 5, 2007 Author Report Posted March 5, 2007 i use hammerite Check my thermostat cover thingy filthy job to clean things but gets good results
X-pack-Glyn Posted March 5, 2007 Report Posted March 5, 2007 Engine paint for iron blocks,ive had excellent results with brush on smoothrite in blue/black/red before, the only place it wont work is around the exhaust ports. steel or ally just polish it up . any pressed steel parts should be blasted and either pollished or use spray on paint. the lazy b,stard route is a good clean and satin spray the lot.
