kev the rev Posted June 2, 2023 Report Posted June 2, 2023 ok so ive got the top hinge pin out with various modified drifts and punches but how do you get the bottom pin out as you cant get in from the bottom of door ,no room , and cant see how u drive it out from the top side as the pin will hit the inner door body at the bottom ,bloomin nightmare
Steve1967cortina Posted June 2, 2023 Report Posted June 2, 2023 Do they not have bolts in the A pillar? I don’t remember having to do that in the distant past on mk2 escort.
Miniliteman Posted June 2, 2023 Report Posted June 2, 2023 Have you removed the pin in the door-check arm? Ford used a special tool, 41-002. If you google that number you probably will see what it is.
Steve1967cortina Posted June 3, 2023 Report Posted June 3, 2023 There are pin removal tools on eBay that may do the job, looks like it pulls them out rather than drifting it with a punch https://www.ebay.co.uk/itm/311596359195?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=mNxrbkO5Sx6&sssrc=2349624&ssuid=MAHfsQCtQBe&var=&widget_ver=artemis&media=SMS
kev the rev Posted June 3, 2023 Author Report Posted June 3, 2023 10 hours ago, Steve1967cortina said: Do they not have bolts in the A pillar? I don’t remember having to do that in the distant past on mk2 escort. the doors off mate its the hinge pin im trying to remove
kev the rev Posted June 3, 2023 Author Report Posted June 3, 2023 1 hour ago, Steve1967cortina said: There are pin removal tools on eBay that may do the job, looks like it pulls them out rather than drifting it with a punch https://www.ebay.co.uk/itm/311596359195?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=mNxrbkO5Sx6&sssrc=2349624&ssuid=MAHfsQCtQBe&var=&widget_ver=artemis&media=SMS cheers mate il get one and give it a go thanks
caprimk1v4 Posted June 3, 2023 Report Posted June 3, 2023 I used plenty of local heat from a oxy/acetylene torch with a very small nozzle, knocked it downward, and kept cutting off the protruding bit with a Dremmel saw with Carbide miniature disc, slow going, but it got it out. 1
kev the rev Posted June 3, 2023 Author Report Posted June 3, 2023 42 minutes ago, caprimk1v4 said: I used plenty of local heat from a oxy/acetylene torch with a very small nozzle, knocked it downward, and kept cutting off the protruding bit with a Dremmel saw with Carbide miniature disc, slow going, but it got it out. hi thanks for the info ,if the removal tool doesent work il resort to your method ,cheers for the info
kev the rev Posted June 13, 2023 Author Report Posted June 13, 2023 so i bought the sealey door pin removal kit about 22 quid off ebay , comes with three different sized pin insert bolts , ,put the bolt that fits inside your door pin, attach threaded nut then insert square bar tool under the head of the through bolt and hammer upwards or down wards depending on which hinge pin your removing , upper or lower , a few taps and out it came although this one was in two halves , others came out whole but very rusty ,, job done 1
anglia58 Posted June 13, 2023 Report Posted June 13, 2023 that's the right tool, when hitting it with a hamer the fibrations will go to your hands, nice he !!!!!, i change the pins with bolts and nuts, but when you replace the pins make sure you got the thick ones, the thin ones won't last long, cheers marcel 2
kev the rev Posted June 14, 2023 Author Report Posted June 14, 2023 16 hours ago, anglia58 said: that's the right tool, when hitting it with a hamer the fibrations will go to your hands, nice he !!!!!, i change the pins with bolts and nuts, but when you replace the pins make sure you got the thick ones, the thin ones won't last long, cheers marcel i bought the thick stainless steel ones marcel so hopefully theyl be ok
