Guest cortinamad-gonetoo Posted August 16, 2007 Report Posted August 16, 2007 at the moment im running a 1.6 pinto on a twin choke down draught (32/36) its good on fuel but a bit flat on pick up sometimes if i put a degas carb on what milage to the gallon shoud i expect or if i put 45s on what should i get to the gallon i need some idea first as i use the car reguarlly for road use
Mart Posted August 16, 2007 Report Posted August 16, 2007 wouldnt bother putting 45's on mate seems a waste to throw that fuel down their throats without the rest of the engine mods, how aout just dumping the 1.6 for a 2ltr injection? more power and still keep a half decent fuel consumption
Admin Vista Posted August 16, 2007 Admin Report Posted August 16, 2007 45's would probably be a little big for a 1600, you'd need small chokes and jets so you'd likely be better going for the cheaper 40's if you want twin carb sound. How much fuel would it use? Sorry mate no idea
Guest cortinamad-gonetoo Posted August 16, 2007 Report Posted August 16, 2007 what about the degas from a 3.0L capri i wanna get atleast 25 to the gallon really
xpackken Posted August 16, 2007 Report Posted August 16, 2007 no chance davey mate i like the dgas carb mate i had one on my 2.1 fr32 fast road cam lods of other mods and it was ideal did a rolling road @ 149 bhp . so there good but on a 1.6 pinto mate not worth it at all . i allways found aswell that the 1600 were shit on fuel compared to the 2.0 because your allways reving the balls out of em . i wouldnt put anymore fuel down the neck of that little pinto because it wont benifit itll just make things worse . two litre it dave you know it makes sense _________________ Mercedes Benz MB100
Mart Posted August 16, 2007 Report Posted August 16, 2007 yeh 2ltr it instant power gain and no messing about swapping carbs i wont tell your insurance company if you dont
Guest cortinamad-gonetoo Posted August 16, 2007 Report Posted August 16, 2007 so when i 2.0L it which is on the cards any way which carbs for power but economy too like i said about 25 gallon
bortaf Posted August 16, 2007 Report Posted August 16, 2007 If you already have a 2.0 carb on there that flat spot is caused by the chokes being too large already, the DGAS will only make it worse, the twin webber the GT spec 1.6 came with uses smaller chokes than the 2.0 If you need to keep a 1.6 then mod away but if you don't, even if you started with a GT spec 1.6 and modded it you'd spend around £500 to get the same BHP as a 2.0 and still have less torque (and thats what counts in a road car) the only plus the 1.6 would have would be it likes to rev quicker but by the time you've got the power up to 2.0 level you'll need the bigger 2.0 flywheel and clutch to handle the power which will make the 1.6 rev slower due to the extra weight it will have to accelerate so there goes any pluss points. I like something different meself been the 1.6 route but TBH unless i had a Mk2 mexico (origonality counts here for me) i'd do as i allways do and slot the 2.0 in, leave the 1.6 diff in and round town it'll fly, fit a 5 speed for the occasional motorway trip Don't wanna sound like i'm telling you can't do it but £ for £ the 2.0 is the best option especially as your starting with the lower non GT spec engine
lee_capri Posted August 16, 2007 Report Posted August 16, 2007 dave put 2.8 in it all you need are the 2.3 engine mounts and use the 2.8capri box just spin the gear box bracket round and bobs your uncle and the 2.8 wouldnt be any dearer to run thana 2.0l and the 2.8 would make a bad ar*e tina
bortaf Posted August 16, 2007 Report Posted August 16, 2007 so when i 2.0L it which is on the cards any way which carbs for power but economy too like i said about 25 gallon Dam answerd while was typing The standard twin choke is good for around 140 BHP after that it becomes restrictive, by the time you've got a DGAS had it rejetted or set up propperly you could buy an ashley manifold and gain more power, more drivability (torque) and probably better millage as the engine will be running more efficiently.
Guest cortinamad-gonetoo Posted August 17, 2007 Report Posted August 17, 2007 ive been thinking today im going to do all my other mods first suspension rs clocks few other things then the engine prob 2.0L pinto i have thought about 2.8 i though
