mk2griff Posted September 5, 2007 Report Posted September 5, 2007 my new project mk2 escort 4dr 1 owner from new.elderly gent in his 80s has had small bump so need wing o/s front panel bumper and grill. best places to buy all the bits.can i convert from square head lights to round or will both fit the same front panel.
escort new boy Posted September 5, 2007 Report Posted September 5, 2007 you can get wings and a front panel from your local panel shop round headlight grills are fetching quite a bit at the minute so id keep that in mind
antz Posted September 5, 2007 Report Posted September 5, 2007 i THINK to fit round headlights all you need are the lights and the grill but the grills fetch anywhere from £30 for a damaged one to £100 for a mint F-O-R-D lettered one so bear that in mind! as said before youll be able to get panels from your local panel shop
mk2griff Posted September 5, 2007 Author Report Posted September 5, 2007 Thanks for that i do prefer round lights though.found wing and panel on ebay,that will do the job.just waiting for delivery costs.next rip out the tiny 1300 xflow and put something BIGGER in.
c1arke Posted September 5, 2007 Report Posted September 5, 2007 wat are you going to be doing with the 1300??? and Wat's it like running?
mk2griff Posted September 5, 2007 Author Report Posted September 5, 2007 NOT sure yet got to find 1600xflow or pinto to go in.but sounds sweet as.it was driven by old guy in his 80s.done 80.000 about 4000 a year if my maths are anygood.when it comes out you will be first on the list.
escamino Posted September 5, 2007 Report Posted September 5, 2007 Backing bowls are different for the round headlamps.
antz Posted September 5, 2007 Report Posted September 5, 2007 Backing bowls are different for the round headlamps. thought they might be but wasnt sure nowt wrong with square lights
c1arke Posted September 5, 2007 Report Posted September 5, 2007 NOT sure yet got to find 1600xflow or pinto to go in.but sounds sweet as.it was driven by old guy in his 80s.done 80.000 about 4000 a year if my maths are anygood.when it comes out you will be first on the list. thanks mate cause i mite have bout a mk1 shell so need an engine lol
mk2griff Posted September 6, 2007 Author Report Posted September 6, 2007 Many thanks for all your help.think iv found another mk2 locked away in a garage for 12yrs try to find out more today.thats three in two days.my luck must be changing.
Miller Posted September 7, 2007 Report Posted September 7, 2007 Ive just converted my saloon to round lights yesterday, nice and easy swap in theory but as has been said youl need the backing bowls as well (as they have a hook which a spring connects to from the light to hold it in and allow for adjustment). But as always with old cars its never that easy and I spent a good 4 hours dealing with stuck self tapping screws, cleaning headlight bowls and removing dead bits of front panel before I could do the swap. Only other problem I encountered was that the sealed beam round lights use different side lights than the square ones which is something to bear in mind. As said round grills are silly money and stock round lights offer no advantage over squares although there is better choice options available that will fit in a round light grill (for example VW golf and landrover headlights). On a road car its really down to personal taste.
bomber1 Posted September 7, 2007 Report Posted September 7, 2007 if ur determind to go for round headlights is to find a local mini shop and buy a set of halogen conversion lamps with backing bowls. that way u can up rate the bulbs
Miller Posted September 7, 2007 Report Posted September 7, 2007 Aye thats what I ended up doing in the end becuase the selaed beams were crap (but then so were the square ones), you still need the round lamp backing bowls though as that silver trim ring clamps the lamps in place. That way you also get around the side light problem where on some lamps there is no window for one to shine through. *edit* just read that properly: my halogen kit didn't come with backing bowls but if you can get them with then yes you would be able to do without.
mk2escortmad Posted September 7, 2007 Report Posted September 7, 2007 i got a N/S wing if you want it for £35
mk2griff Posted September 7, 2007 Author Report Posted September 7, 2007 THANKS to all car will have new front panel so no probs with knackerd screws.thanks for offer of n/s wing sods law that i need o/s.have some photos this week.
mossy Posted September 7, 2007 Report Posted September 7, 2007 whats these cars you found...and are they for sale?
mk2griff Posted September 8, 2007 Author Report Posted September 8, 2007 GOT 4door for me and my son.the other is mk2 estate not sure of condition.the other is mk2 ghia waiting for owner to get to me sometime this week.dont even know if its 2 or 4dr.if its a2dr it will be coming home with my other osf,s.
