antz Posted November 7, 2007 Report Posted November 7, 2007 i had a thought.... im gonna be fitting a line lock that works off a fancy momentary button in my escort soon and as with msot thigns i wanna keep it looking standard.... mossy said i should put the button in the ash try and it got me thinking would it work if i removed the ash tray and inserted a metal plate 1/2 the width of the ash tray in place and put on ym switch then cutting up an ash tray so i had the face of it and fitting it back up so i still had the look of the tray, the swivel of teh tray but inseatd of a palce to put ya fag it was just a covering for my hidden switch or am i been a complete twat and thinking silly ideas
FlashCadillac Posted November 7, 2007 Report Posted November 7, 2007 having never been in a mk2 escort iv no idea what your talking about bet that post was really usefull to you!
Rick Posted November 7, 2007 Report Posted November 7, 2007 yeah stick the fag lighter nob on the end of your switch you can line lock your brakes when you park it up too so any thieves will have to drive with brakes on
antz Posted November 7, 2007 Author Report Posted November 7, 2007 yeah stick the fag lighter nob on the end of your switch you can line lock your brakes when you park it up too so any thieves will have to drive with brakes on in on about putting it in where the ash tray should be and using a cut up ash tray as a door to hide it plus its on a momentary swicth so as soon as i let go of the button the brakes come off
PaulAshman Posted November 7, 2007 Report Posted November 7, 2007 Something like that would work fine. On my old capri it had push button start and it was the fag lighter end on the switch. Well concealed out of the way.
antz Posted November 7, 2007 Author Report Posted November 7, 2007 hmmm.....might have to try and get a spare console bit and ash tray to have a trial run on
Copey Posted November 7, 2007 Report Posted November 7, 2007 hmmm.....might have to try and get a spare console bit and ash tray to have a trial run on probably be for the best!
antz Posted November 7, 2007 Author Report Posted November 7, 2007 TO EBAY I GO!!!! ...bloody high prices
mossy Posted November 7, 2007 Report Posted November 7, 2007 my mate cisco23 did it with his leccy fan and his other switches...bit of thin wood made to the shape of the ashtry with pre-drilled holes and switches...Wire it all up and drill one large hole in the back of the ashtray feed wires through, connect to switches fit in plywood close ashtray...Job Done!
antz Posted November 7, 2007 Author Report Posted November 7, 2007 my mate cisco23 did it with his leccy fan and his other switches...bit of thin wood made to the shape of the ashtry with pre-drilled holes and switches...Wire it all up and drill one large hole in the back of the ashtray feed wires through, connect to switches fit in plywood close ashtray...Job Done! sounds complicated can you get me any pics?
mossy Posted November 7, 2007 Report Posted November 7, 2007 just get a thin peice of plywood...and keep trimming it till it fits in the ashtray add switches to wood drill hole in rear of ashtray for wiring feed wires through hole connect to switches fit wood in tray....close tray smile in the fact nobody knows they are there!
oliwally Posted November 7, 2007 Report Posted November 7, 2007 Right I've been thumbing my way through MoT manual,Yes line locks ARE part of an MoT. They're part of hand operated brake valves,They need to be in good working order,lever or control move freely from open to closed,securely fastend and not leaking. They also need to fitted where they can be easily to reach.
antz Posted November 7, 2007 Author Report Posted November 7, 2007 but the ash tray spins round so it wont work will it? im thinking of using the ash tray as a door that opens to reveal teh switch
mossy Posted November 7, 2007 Report Posted November 7, 2007 hmmmmm his was a drop down one in a capri.....bugger!
surfingturnip Posted November 7, 2007 Report Posted November 7, 2007 I think I know what you're on about, it could and should work as well. Shall discuss it if I see you at the weekend
jimbo Posted November 7, 2007 Report Posted November 7, 2007 How about something like this? Use your donor ashtray to give you the front. Fit a panel behind with the switch Use a couple of appropriate hinges to give you the drop-down front. Make sure they have sufficient clearnce so thet the front doesn't snag as it drops down. Something like this.................. You might get a donor hinges from one of those plastic boxes that hold reference cards. For the catch at the top you can get a push close thing, like those fancy Brabantia bins (They are actually available as spares.) A bit of carefully applied araldite and there you go. Should cost you less than a tenner
petrolhead01 Posted November 8, 2007 Report Posted November 8, 2007 tony petrol guy did it in his 100e antz it will be very easy and you could do this in a swiveling astray but of coarse you will only be able to move the astray open and closed one way!!!
Mr Sam Posted November 8, 2007 Report Posted November 8, 2007 i was about to say.... you could do it so when you open the ashtray it turns it on that could be disaterous though if a passenger opend it while on the road need a kill switch somewhere under the dashstick it under the edge of your seat
jimbo Posted November 8, 2007 Report Posted November 8, 2007 Very 007 On a similar note. I've got a pedal next to my brake that, if I press down, leaves an oil slick behind the car
Toby Posted November 8, 2007 Report Posted November 8, 2007 Very 007 On a similar note. I've got a pedal next to my brake that, if I press down, leaves an oil slick behind the car
Dom Posted November 8, 2007 Report Posted November 8, 2007 On a similar note. I've got a pedal next to my brake that, if I press down, leaves an oil slick behind the car Must be a special order one then, mine turns the windscreen wipers on
antz Posted November 8, 2007 Author Report Posted November 8, 2007 tony petrol guy did it in his 100e antz it will be very easy and you could do this in a swiveling astray but of coarse you will only be able to move the astray open and closed one way!!! it only slides open if you press the elft side anyway im thinking of using the face of an ashtry to keep the swivel movement and hiding the switch behind it...then again a drop down one does sound good..if nto mroe complex
