kevmk2 Posted October 22, 2005 Report Posted October 22, 2005 Body: Stock RS2000 Shell,Fibreglass bonnet and bootlid. Doors drilled for lightness with starret Cutter. Grp4 Style Large Gearbox Tunnel. Single Wiper from Fiat Uno. Colour Radiant Red Engine: Bottom end: Cosworth YB. Ford Motorsport 200 Block Coopers Rings Cosworth Forged Pistons 8:6:1 compression ratio Knife Edged Crank RS500 Rods Oil spray jets H.T Racing Big winged baffled Sump Long Studded head bolts. Bailey Oil Seperator. Dynoed @ 405bhp and 450 Ft Lbs Torque (Field Motorsport Dyno) Top End: WRC Head Ported and Polished Double Valve Springs BDG Spec Lowered Platforms in head BD14 Inlet Cam BD8 Exhaust Cam Phase sensor on rear of rocker cover for dizzyless ignition Turbo: T34 Hybrid With Restrictor pipe fitted but unrestricted (waisted inside) Forge -34 Actuator .63 Exhaust Housing. Injectors/Fueling: 8x Dark Blue injectors WRC Inlet Manifold O-Ringed to head Mountune Fuel Regulator (5.0 Bar) -6 Braided Fuel hoses throughout the car,run inside. Bosch 044 Fuel pump Holley 110 Gallon per hour lift pump Alloy Swirl pot. Cooling: The Rad and intercooler are made for cosworths,my mate jason made them fit an escort. Pace 50mm Rad. Radtec RS500 intercooler. 2wd Cossie Fans. Silicone Hoses throughout. Bailey Swirl Pot. Pace one off Header tank. (thanks dan) Electrics: P8 ECU with Anti lag and pectel piggy back board. Zetec Coil pack. Ford Motorsport Plug leads. Motorsport wiring loom. Twin Ignition modules. Exhaust: Mongoose 2wd Sierra downpipe cut and shut to fit. Hayward and scott stainless centre section. Mongoose 2wd Sierra Rear box modded to fit. Transmission: 2WD Flywheel and AP 4 Paddle Clutch T5 Borg Warner Gearbox Pro 5.0 Mustang Shifter One Piece Prop (bespoke) Hydraulic clutch. Axle: Atlas Axle Shortened By H.T Racing Quaife Grp1 Two Piece Halfshafts With ZF splines Zf Motorsport LSD with twin clutch plates. 70% lock. 3:7:5 Diff Ratio Suspension: Front: Gartrac Bilstein 300/70 rated short legs with 2 1/4"350lbs springs. Rose Jointed top mounts (eccentric). Alloy Hubs. Rose jointed adjustable Track control arms. Rose jointed compression struts. No anti roll bar. 2.0 Degrees Neg camber. Rear: Leda 24 point Adjustable 2 1/4 Coilovers with 14" 150lbs springs. 5 Linked with rose joints. Brakes: Bias Pedal Box made by H.T Racing All Brake lines Braided and run inside the car. Hydraulic Line Lock. Front: 310mm two piece Vented Discs with AP Racing 4 Calipers. Ferodo DS3000 Pads. Rear: XR3i Front discs and calipers mounted on axle. Ferodo Standard Pads. Alloy Fly off handbrake. Wheels And Tyres: Compomotive ML 7x15 Grp4 Style 195/45 Toyo Proxes TS1 Tyres. Interior: Sparco Evo Seats. Willans 6 Point Harnesses (FIA SPEC) Stack ST700SR Tacho/speedo with boost display and fuel pressure. Racetech Oil pressure gauge Racetech Water Temperature Capillary gauge. Smiths Fuel gauge. All mounted in carbon fibre. 12 point Safety Devices Roll Cage. Welded in. Ralloy Alloy centre console with relays and switches. Rs 4 Spoke Steering Wheel,on quick release hub. Dash top flocked by Central Blast Cleaning. Standard Rs2000 Door cards. Alloy firewall. Large diff tunnel. No heater. Underside of car painted body colour.
redone Posted October 22, 2005 Report Posted October 22, 2005 oh dear, I seemed to hav made a mess again fookin love this car!! P.S.... wanna swap?
Pipster007 Posted October 22, 2005 Report Posted October 22, 2005 That is a lovely Escy Seen it a few times now
Steve_D Posted October 23, 2005 Report Posted October 23, 2005 Ive got a list of 3 escorts tht i would luv to own and yours is one them mate i luv your car
105Ian Posted October 23, 2005 Report Posted October 23, 2005 Great looking car mate ,has to be the best looking RS2000 at the moment.
kevmk2 Posted October 23, 2005 Author Report Posted October 23, 2005 Cheers Lads,thought it was about time i put a thread on here about it
Johnson Posted October 23, 2005 Report Posted October 23, 2005 Kev your car is an example of what can be done with loads of attention to detail. ive seen it in the flesh and it is mental mate. never sell it. keep it and rag it.
omj624p Posted October 23, 2005 Report Posted October 23, 2005 Cheers Lads,thought it was about time i put a thread on here about it Wanna swap?
kevmk2 Posted October 24, 2005 Author Report Posted October 24, 2005 Cheers Lads,thought it was about time i put a thread on here about it Wanna swap? Erm let me think.... No
cracker Posted October 24, 2005 Report Posted October 24, 2005 She is a beast Kev, just love it. cheers Cracker
AdamB Posted October 24, 2005 Report Posted October 24, 2005 that the rolling road at engine advantages? awesome car dude
Daz271 Posted October 25, 2005 Report Posted October 25, 2005 well done mate, that is one sweet RS.. im being hypnotized by your avatar!!
DEP Posted October 25, 2005 Report Posted October 25, 2005 Hard as nails your car Kev, i ve still got the poster on my garage wall from when it was first featured in CF with the 190 bhp pinto and 15 ins imolas on it
puddy Posted October 25, 2005 Report Posted October 25, 2005 Gotta say kev ,apart from darrans old mex ,yours is deffo one of my " all time top ten favourites" said in a smash and nicey sort of style! puddy
sidewayz Posted October 26, 2005 Report Posted October 26, 2005 you have a sweet sweet sweet ride mate, i cant get enough of her, look after her LEE
kevmk2 Posted October 27, 2005 Author Report Posted October 27, 2005 that the rolling road at engine advantages? awesome car dude Yes mate
kevmk2 Posted October 27, 2005 Author Report Posted October 27, 2005 Hard as nails your car Kev, i ve still got the poster on my garage wall from when it was first featured in CF with the 190 bhp pinto and 15 ins imolas on it Still got one myself mate,brought a mint one off ebay last year too lol,bloody £5 it cost me
kevmk2 Posted October 27, 2005 Author Report Posted October 27, 2005 Gotta say kev ,apart from darrans old mex ,yours is deffo one of my " all time top ten favourites" said in a smash and nicey sort of style! puddy Cheers Mark,yours is in my top ten too
puddy Posted October 28, 2005 Report Posted October 28, 2005 Gotta say kev ,apart from darrans old mex ,yours is deffo one of my " all time top ten favourites" said in a smash and nicey sort of style! puddy Cheers Mark,yours is in my top ten too puddy
Col-ashtonmobile Posted October 28, 2005 Report Posted October 28, 2005 yeah luv that car fooking awesome
SLYMAN Posted October 29, 2005 Report Posted October 29, 2005 I noticed Kev you put .63 housing in Turbo spec, its fitted then? whats it like then?
