I have done a pretty thorough search and the consencus seems to be that most people run their OSF on 20/50 oil.
The thing is, my essex V6 sends the oil pressure needle off the top of the scale when it starts up and doesn`t really drop much even when warm and on tick over.
I wonder if I could do with a 10W/40?
What do you reckon?
It sounds to me like your pressure relief valve may be stuck. Oil pumps are usually high volume not high pressure. Get it checked with an accurate gauge. Too high an oil pressure can do all sorts of damage to seals and gaskets! :sad:
Thanks for all the replies :thumbsup:
I will get the Valvoline 20/50 for the next change and if I get the oppurtunity I will check the accuracy of the gauge.
I use Millers 20/50 Classic Sport semi-synthetic in my 3.0 Essex.
Guage goes to three quarters up when cold and settles to just over halfway once warm :thumbsup:
That's with a standard oil pump.
HT's use valvoline racing 20/50 in their engines,if its good enough for a race engine then its good enough for anything :ykt::thumbsup:
Exactly what Steve @ Vulcans told me to use in mine when he built it. They did a breakdown test on different oils, and Valvoline was miles ahead of the rest.
I had at least 3 cam failures - worn lobes, untill I went to Valvoline 20-50, no problems ever since. :thumbsup:
All the Valvoline stuff is great, diff & gear oil too. :thumbsup:
