Depends what you mean by Cologne V6 as there were quite a few variants.
The most common one over here is the 2.8 fitted in injection and carb formats to Mk3 capri 2.8is and Mk2 grannies. The early 2.8i boxes were 4 speeders but they went 5 speed from about 1982/3 so the bulk of cologne boxes as fitted to capris will be 5 speed. Grannies are harder to quantify, first of all because I don't know much about them, and secondly because there were a lot of Grannies with auto boxes.
I should have mentioned in my previous reply but as far as I know all the 5 speeds fitted to cologne engined cars were Type 9's, albeit slightly different from the 4 cylinder type 9's as the ratios are slightly different and the input shaft is longer (I'd forgotten about the XR4i)
the 2.8 V6 cologne 5 speed gearbox was as vista said a type 9 as fitted also to the mk2 granny 2.8s & XR4i's almost the same as the pinto type 9 5 speed (which will fit a xflow) as vista says longer input shaft plus bellhousing bolt pattern completely different. best advice i would give is sell it on again
and buy a pinto 5 speed type 9 your box is worth more so you should make on the deal :thumbsup:
if you stand your box on its end it should not sit flat as the input shaft is poking out the end. A pinto one will sit flat as the shaft is shorter
If it's a sierra one it will prolly be the XR4i box with the uprated input bearing :thumbsup: all other V6 sierras where 4X4 or auto (in the UK anyhoo) i believe ?
Worth a bit more than the capri one to a 24V owner cos it should last longer :mrgreen:
the uprated ones and a 3 bolt plate on the front so the bell housing is slightly different to clear it, there was an artical a few months back in classic ford telling how to ID the different T9 boxes but damed if i can find it now :roll:
