i used it on my old mini engine but sold the car a month later so couldnt tell you if its still ok or not
seemed ok for the month after i did it lol
Smooth blue hammerite,always worked fine for me :thumbsup:
i use smoothrite on bike engines without any probs, didnt know they did blue tho?
is it a good light blue, like the powder blue ive seen under osf's bonnets?
Pretty sure Jeff Harris uses Hamerite, I used to and now use Halfords engine laqure, no problems ever and a really nice gloss if that's what you're after - some people say gloss is naughty on engines cos it hides oil leaks, but I say you can always look on the drive for those!! :mrgreen:
I clean the block off with a wire wheel to bare metal,etch prime it with if in a diy situation u pol acid 8 etch aerosol get em from halfords ,let cure for a little while then brush two pack paint on with the hardener mixed in ,no thinners. That lets you do whatever colour you want ,ive always found that bullet proof and lasts for ages. :)
Could'nt tell you how it holds up as the engine is still sitting in the shed :lol: but this is hammerite smooth blue,painted my engine a couple of weeks ago :thumbsup:
i used some engine paint that you have to mix with the hardner...so far its doing well...no peeling etc....just make sure you clean the block fully and no grease left on it....havnt got the name handy of the stuff atm but this is how it came out
:thumbsup:
that ebay link engine laquer is £3.99 at wilko motorsaves ;)
and its good stuff!!!
i used it on the old pinto, sticks like sh** to a blanket, unless theres bits of oil underneath then the oil tends to put "bubbles" in the paint.
good stuff though, nice blue too!
