trying to get the steering wheel out of my Ford, it's the three spoke one. i'm sure you know what i mean!
i popped out the ford logo and rubber surround, undid the nut, and the wheel wouldn't pull off.
ok i thought, i might be able to see the problem if i remove the indicator cluster etc.
nope.
what am i missing? it shouldn't be this hard to take a bloody steering wheel off surely! :evil:
undo the nut and it should pull off but if its not been taken off fora few years it might be stuck,squrt some wd40 down there
You've done all the right things it's probably just stuck as it's been on there so long. I remember having to be quite forceful with mine when I wanted to fit a replacement stalk switch.
Try what's suggested above :thumbsup:
okay thanks for your quick responses, i'll keep you updated...
Make sure you post up the pic of the black eye you get when it comes off suddenly at high speed :lol:
Someone told me mine would be stuck on, so I removed the nut, and pulled as hard as possible!!!
The resulting nose bleed says it all :roll:
Now I always just loosen the nut, never take it off fully!
loosen the nut off and turn out a few turns and then with both hands thump the back of the steering whel both sides at the same time the wheel will eventualy pop out then remove the nut and the wheel will then come off when you replace it make sure the wheel is in the exact same position or you will drive with the wheel p**sed
