you need the crank /clutch/front pulley all together to balance a flywheel
or you can buy a CNC machined f/wheel from burtons :thumbsup:
mine is 4.5kg, only notice it if you drop the clutch at very low RPM
general driving and taffic's ok
sorry for the thread hi-jack, but is your name darran?
I bought a few rs alloy bits off you a while back? RS dipstick tube?........
:thumbsup: dealt by phone and post etc....?
Guest cortinamad-gonetoo
what happens if you just get the flywheel machined so its lighter then just fit it
i bought a lighened flywheel off ebay and fitted it to a pinto i didnt get anything balanced and it went ok
just thinking of doing the same again to the pinto i have now
what exactlly does the balancing do ??????
I machined about a 1/2 of the weight off my pinto flywheel but as there were no balance drillings on the counter weight on the back and no cold spots in the casting and was clocked up to 5-10 microns run out never felt the need to get it balanced again and seems ok till now.....fingers crossed :thumbsup:
Looks like a Titan flywheel to me :wink: Shameless plug :oops:
aint the coggy thing hanging down ment to be on the fly wheel? :wink:
Have you ever had a road wheel out of balance ? Same thing :thumbsup:
sory i meant do you have to get it balanced to the crank
or is it ok just to fit a lightend and balanced flywheel to your car with the crank as it is :?
  • 1 month later...
gave it a good ragging (sorry gentle drive ) down A1(M) after a while it started to make a funny (laughfter) noise...
stopped at services to see, nothing wrong unttill i started it up. it just fell off.....
bumped it to get going and drove it home, no noise or knocking parked up and that's what i found.
it's now tack welded on, F**ck the balance it works. :beer:
