I've been over at StevePeanuts this morning to help swap his gearbox from auto to manual on his Mk2 Escort 1600. We still have the pedal box to do, but we've got a problem with the gearbox crossmember.
As you can see from the picture, the crossmember is nowhere near the mount on the gearbox. What gives?
Do the mounts have to be moved? Or is there a kit available that makes it fit the existing holes?
Is it a 4 or 5 speed box ?
Looks like you may have to make some extension mounts similar to if you 5 speed a car ?
Someone posted a pic on here a few days ago of some he had made.
It basically 2 pieces of box with holes drilled through one end bolts through the car body the other through the gearbox mount.
I had the same problem. You can:
drill out the spot welds on the mounts and relocate them further fowards OR
modify the existing crossmember similar to pics above (which is what I did)
OR
fabricate you own crossmember, which would look like a big 'V' when viewed from above
Good luck :thumbsup:
I have an idea, which involves leaving the crossmember in the correct position on the car. Then putting a block in the gap between the top of the crossmember and the bottom of the gearbox. Then using some kind of U bolt as used on axles. This could loop over the gearbox then with 2 holes drilled in the crossmember it could bolt to that.
I'll loosely fit this together at some point and put a pic up
