FredTransit Posted July 16, 2009 Report Posted July 16, 2009 Not me, there are some guys on a charity rally to Mongolia. They are currently in the Germany. They have a 1996 ES v8i (with LPG) Auto disco that very recently had a new tank. Here's what's up. Dodgy petrol feed has us once more in a motel. Waiting for the Landrover dealer to open somewhere about 50 miles west of Dover. They had the tank flushed and found loads of crap in it including bits of wire. They got on their way again, then today Towed in last night, again AM. Dies every 50 miles, 1 hr wait to restart. Going to 3rd dealer tomorrow AM. If not fixed will have to bail. Anybody any idea what it could be?
mk3cokebottle Posted July 16, 2009 Report Posted July 16, 2009 could be the sedimenter in the petrol tank thats fooked or a dodgy earth on the fuel pump ??
mk3cokebottle Posted July 16, 2009 Report Posted July 16, 2009 if they can run it on lpg and only need fuel to start it then suggest that they make a bypass tank out of a jerry can so they can start it in the morning and warm it up then change it to lpg for long runs ......
FredTransit Posted July 16, 2009 Author Report Posted July 16, 2009 That's the thing, I think they said they were out of LPG and thought that was it. I said didn't matter what fuel it's on, it should start and run (if it's warm)
PAUL MANN Posted July 16, 2009 Report Posted July 16, 2009 could be fuel pump relay playing up,or fuel pump,or tank breather losen fuel cap so its not air tight
FredTransit Posted July 16, 2009 Author Report Posted July 16, 2009 I think the new tank is a connection, maybe it is a breather problem.
FredTransit Posted July 17, 2009 Author Report Posted July 17, 2009 Anybody want this? Sounds like the blokes are going to ditch it cos it's cut out three times in 250 miles..... It's in Frankfurt......
sidspop Posted July 18, 2009 Report Posted July 18, 2009 Try starting withoout filler cap on, could be tank is vacuuming if breather blocked./ Try removing fuel pipe at carb end, and blowing, could be shit blocking outlet from tank. Try jerry can idea, possibility of rubber fuel pipe closing up on itself in fuel line.
FredTransit Posted July 18, 2009 Author Report Posted July 18, 2009 They did run it without the cap on, no joy. I think they have about had enough of it now...
FredTransit Posted July 18, 2009 Author Report Posted July 18, 2009 they are up and running and on their way again! Just had a text to say they have crossed into Austria, and am waiting to see what the problem was. Thanks for the suggestions
FredTransit Posted July 19, 2009 Author Report Posted July 19, 2009 Yep the coil was replaced by the 4th landy dealer and now all seems well....
