seaneylad Posted October 22, 2015 Report Posted October 22, 2015 Good Afternoon Due to ongoing wheel wobble for over a year ... Ive been told to check steering column and replace bushes as its been known to fix the issue.As i have tried everything esle .. so this is like last chance saloon, give up if this doesnt resolve it haha.My question is where do i buy them from, i have found ones for the mk2, will they fit my mk1 okay? If there anything else i should be looking for on the column as possible area to cause the issue? Bottom steering column bush: Ford Escort Mk2http://www.burtonpower.com/bottom-steering-column-bush-ford-escort-mk2-mp1011.html Top steering column bush: Ford Escort Mk2http://www.burtonpower.com/top-steering-column-bush-ford-escort-mk2-mp1010.html Any advice as always is appreciated. Thanks
seaneylad Posted October 22, 2015 Author Report Posted October 22, 2015 The other thing i noticed, the other day when i jacked the car up and spun the front wheels they seems to move up and down slightly on both side, not perfectly rotating if that makes sense.Its had new discs, tried new hubs from gs escorts, new bearings, has the legs turned into coilvers with 200lb springs. Its only every slightly but if you look at the wheel in once area and spin in it goes above and below that line. Could that be an issue? Possible stub axle or? does it on both sides?Im lost now checked everything atleast 5 times now and all is okay
robert 1600E Posted October 22, 2015 Report Posted October 22, 2015 Have typed changing the front wheels to see if it makes any difference
craige1979 Posted October 22, 2015 Report Posted October 22, 2015 I bought mk2 escort nylon bushes, filed then to a snug fit, little bit of grease . Done,.. No movement, car drove perfect., I had done all the changes and had so much helpful but not problem solving advise...
seaneylad Posted October 22, 2015 Author Report Posted October 22, 2015 I bought mk2 escort nylon bushes, filed then to a snug fit, little bit of grease . Done,.. No movement, car drove perfect., I had done all the changes and had so much helpful but not problem solving advise... Same here i have had loads of people on OSF here and on FB give me advice, all valid and good but hasnt solved my issue. 1. I have had legs converted to coilovers with 200lb springs with new roller top mounts up top 2. New steering rack 3. New TCA with polybushed inner and outer 4. New Tie rod ends 5. Checked that the bolts hadnt ovalled the holes in crossmember 6. Rear end has had new single leafs, LSD fitted, poly bushed both ends, Adjustable shocks fitted etc 7. I have also tried a new steering wheel (clutching at straws) 8. Tried a new known good propshaft from a friend with no luck 9. Had 4 wheel alingment and tracking done 3/4 times now 10. Tried 3/4 sets of wheels all balanced, even balanced both sets of mine and fitted new tyres with no luck 11. Fitted nearing wheel bearings and hubs from GS escort up front. 12. Also while i was at it i fitted twin cam anti roll bar with double width kit 13. Had Princess Calipers rebuilt and new discs fitted Still got the issue ... so hopefully ill order these and try get them to fit, and fingers crossed, itll cure my issue.
iandq Posted October 23, 2015 Report Posted October 23, 2015 I would say if your wheels aren't running true, then you have possibly found your problem. do they centre on the hub spigot ok? are the cones where the nuts seat in good condition. has someone replaced the studs or re drilled the hubs ? just a few more things to check ( like you need a bigger list ! ) cheers, ian
seaneylad Posted October 23, 2015 Author Report Posted October 23, 2015 I would say if your wheels aren't running true, then you have possibly found your problem. do they centre on the hub spigot ok? are the cones where the nuts seat in good condition. has someone replaced the studs or re drilled the hubs ? just a few more things to check ( like you need a bigger list ! ) cheers, ian Cheers need to take another look, ive tried another set of hubs with same issue. they where 2nd hand though so possible issue still. This is the video, not the best i must admit, does it look like an issue, maybe not be able to tell from this to be fair http://s732.photobucket.com/user/seaneylad/media/Track%20day/VIDEO0013.mp4.html
seaneylad Posted October 23, 2015 Author Report Posted October 23, 2015 <embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid732.photobucket.com%2Falbums%2Fww329%2Fseaneylad%2FTrack%2520day%2FVIDEO0013.mp4&title=">
colr6 Posted October 23, 2015 Report Posted October 23, 2015 Just watched the vid, nothing to worry about there.
mk1estate Posted October 23, 2015 Report Posted October 23, 2015 sounds like youve covered most things, only thing i can think of is the wheels are not seating properly? are you useing the correct wheel nuts and are the mating surfaces free from anything. Give the rear of the wheels a good look at. Sometimes alloy wheels need special wheel nuts and if your using the original steel wheel nuts then youl get that problem, check everything is clean. Might be worth checking for play on all the front bushes and front crossmember bolts too Like you said in the end you just try anything till you find it good luck anyway and keep us informed
seaneylad Posted October 24, 2015 Author Report Posted October 24, 2015 Just watched the vid, nothing to worry about there. Thats good to know, i was literally clutching at straws like time i looked
seaneylad Posted October 24, 2015 Author Report Posted October 24, 2015 sounds like youve covered most things, only thing i can think of is the wheels are not seating properly? are you useing the correct wheel nuts and are the mating surfaces free from anything. Give the rear of the wheels a good look at. Sometimes alloy wheels need special wheel nuts and if your using the original steel wheel nuts then youl get that problem, check everything is clean. Might be worth checking for play on all the front bushes and front crossmember bolts too Like you said in the end you just try anything till you find it good luck anyway and keep us informed I have had two types or RS wheels on, old originals and new ones, old ones has the nut and washer, and the new replica ones on at the moment have the tapererd nut. Ill keep looking when i get a chance, ordered the bushes for steering column aswell, mayswell rules them out. Cheers
irishtorag Posted October 24, 2015 Report Posted October 24, 2015 bejasuss Seaneylad you have been threw the ropes with that steering. Me im thinking its in your head now or more u have shakey hands lol joking aside i hope you get it sorted ,nothing worse than a small niggle to piss you right off kenny 1
seaneylad Posted October 24, 2015 Author Report Posted October 24, 2015 haha tell me about it Probably cheaper and easier if it was in my head Hopefully ill get there over this winter 1
seaneylad Posted October 26, 2015 Author Report Posted October 26, 2015 Elsewhere some one has mentioned a spigot bearing/ ring? ... Trying to think .. my original wheels where either one of these two types of rs style wheel: Mk2 Capri JPSalloy 5.5J x 13” H71AB-1007-AC-C ETOff set (mm) +19 63mmCentre cap hole size and type: 63mm front fitWheel nuts: Flat washer OR Capri Laser 6J x 13” H81EB - AA ETOff set (mm) +19Centre cap hole size and type: 57mm front fitWheel nuts: Taper nut And my latest wheels are replicals from Midland wheels as show below: http://www.midlandwheels.com/Shop/P-8026-6x-13-JBW-RS-4-Spoke-Black-Machined---ET16.html "RS 4 SPOKE " By JBW Wheels,Traditional Classic Retro Design, Superior Craftsmanship. This Traditional 4 Spoke deep dish Alloy Wheel comes painted In Black with Machined Face. Type: RS 4 SPOKEColour: BLACK MACHINED FACESize: 6 x 13PCD: 4-108Offset: ET 16Fitment: RWD FORDBody Mods: NONE i dont have any sort of spigot bearing in wheel centre, or on the hub currently, could that be the issue? Thanks
seaneylad Posted October 26, 2015 Author Report Posted October 26, 2015 scrap that, Just had a look and my alloys have a centre bore of 63.4mm as per midlands websiteand the legs i have have escort hubs, with ar 63.4mm.
