Hi all
So in the middle of rewiring my car i thought I'd attack the heater not working problem too ( it never has since I bought it )
Now with my understanding of circuits and the wiring diagram I copied from Haynes and the picture from another book I thought this will be easy.....
O how wrong was I?!
I'm not sure wether the previous owner wired it up wrong or each copy I have is incorrect?!
It's a 63 mk1 cortina and it has a booster switch ( which is the main confusion I think )
Is the motor not running at all? Have you tried direct wiring the motor from a battery, only two wires feed and Earth. The resister gives you the slow speed
No I tested the fan switch and resistor all were ok but it's an on off switch an has a pull lever for a boost but as I wanted to wire up the new cable to it I couldn't work out how it should be wired
Not knowing the pre airflow model,don't understand the boost switch, on you heater switch does that give you the two speed? Or is it slow speed and the booster switch gives you fast speed?
From what I can work out from a diagram there is a micro switch listed on yours which I can only think it's the feed for the heater motor and you have only a two position switch slow/fast but no off its the boost switch that turns it off and on. Being the heater was an option on some early cortinas. The later ones having a 3 position switch and no micro switch. Does that sound right?
That makes a bit more sense actually as the way it's wired it looks like a switch then another switch afterwards which is why I was confused? I'll stick some power to it directly tomorrow and see what happens!
I assumed the live would go into the switch, then out to the fan, then off to earth.
That's how the wiring diagram shows it except for the booster switch is wired in parallel to the resistor which is after the switch
How ever looking at it, I have a live into the fan, then out to the resistor and switch, then out the switch to the resistor an booster switch then out the booster switch back into the live connector block?!
No earth??
As the Haynes wiring diagram is chaotic I copied it using colours to match the wires
However reading through the owners manual I think I presumed the operating of the heater wrongly?!!
I assumed the two position switch was on - off an the booster was a boost on top of the fan speed, it reads as the normal operation of the heater is a ram effect with a booster to push air through quicker
Would this seem right?
the booster won't switch the motor on, the micro switch on the controls will do that, that is because you don't want a situation where the fan could be switched on without the flaps open. the fan will normally run through the resistor, and the boost switch effectively by passes it ( bridges it ) to give full ( boost ) speed.
does that seem correct ? I expect the motor earths via it's casing.
cheers, ian
Your second picture strategically missed off the heater / switch circuit LOL so working from your hand drawn - I would say there is ign. volts into the 1st switch which goes through a resistance then to the fan motor with the other side of motor earthed - this will be fan on/off, at low speed setting. When the 'boost' setting is used, it bypasses the resistance and so fan motor gets full volts and so high speed fan? With older cars the application of 'ram air' for the heating / cooling was strictly limited so fans were primarily only useful for circulation and the minimal screen demist - remember the heating water circuit is 'live' at all times so output is dependant on the fan otherwise the occupants would cook through most of the year LOL!
Heaters were a bit primitive on these, the hot / cold option was activated by simply closing the water off by a valve on the head bit like the early minis. The micro switch does activate first speed using control levers via resistor so the motor only runs with flaps open and as stated before boost switch by-passes resistor to give full speed. The later ones just have three way switch and work irrespective of flaps open or closed. As katana says about the wiring diagrams been crap to read do what I do and get the drawings blown up at a copy shop or some stationers, makes them far easier to read and follow the wires lik this,
To this.
Taking it the book in first pic has four diagrams on two pages, very small.
This is the other book I have with the picture altho there's two wires which seem to just stop in mid air?
And this is what I have wired in at the moment
Take a look at this, this should work and give two speeds
If you have toggle/ micro switch on levers and boost switch the 12v feed goes to micro switch first and connects to toggle switch. The earthing might be via Earth on something else
Thanks col thats what i expected to see and thats what the wiring diagram shows it should be.
The way the prev owner wired it up is wrong isn't it? as the two cables coming in to the heater / fan are both live from one connector
The issue I had was understanding which was the main on switch as stupid as that sounds
The booster switch on the heater levers is the main switch, the toggle switch is the speed switch, I was thinking it was the other way round!?
Because the prev owner had wired the earth and feed into the same connector block nothing worked
Now thankfully I can wire this up with the new fuse box an relay and not worry about the thing catching fire haha!
