X-pack-Glyn Posted February 26, 2007 Report Posted February 26, 2007 Front leaf spring bolt stuck fast, wont budge, the bolt is turning but turning the inner bush sleeve along with it. any tricks on getting it out?
mk2 stu Posted February 26, 2007 Report Posted February 26, 2007 Heat that fooker up mate! try some light heat but be mindful of the bush Worse comes to the worse, cut the nut off and tap the bolt through!
Morley Posted February 26, 2007 Report Posted February 26, 2007 Get a new bolt, some WD40 and a big hammer!
V8ian Posted February 26, 2007 Report Posted February 26, 2007 Glyn, have you tried soaking the sleve/bolt and bush overnight in WD40, then give the bolt a good welt with a BIG hammer, other than that there are two ways of doing this, both involve a angle grinder or hacksaw. First method, with an angle grinder and a thin cutting disc, cut up between the spring and chassis rail so the bolt is cut thru, both sides, and the spring should drop down, The second is cut the bolt head and threadded part off flush to the chassis, and gently prize the rails apart and the spring should pop out, or a combination of both methods Support the spring before you do this, cos they do hurt when they fall on you,
escort21 Posted February 26, 2007 Report Posted February 26, 2007 Buy a new bolt and attck the old one with a thin disc cutter...as i said
X-pack-Glyn Posted February 26, 2007 Author Report Posted February 26, 2007 thanks chaps, the nuts allready off. the problem is theres no room to get a hammer on the end of the bolt. i think an evening alone with a disc cutter is on the cards. the spring and bush itself is scrap.
Morley Posted February 26, 2007 Report Posted February 26, 2007 If you had the luxury of air power, i'd reccomend an air hacksaw
johnny_h Posted February 26, 2007 Report Posted February 26, 2007 If you had the luxury of air power, i'd reccomend an air hacksaw If you don't have a compressor, Staples do cans of air for cleaning off computer keyboards.
Jay_harrier Posted February 27, 2007 Report Posted February 27, 2007 If you had the luxury of air power, i'd reccomend an air hacksaw If you don't have a compressor, Staples do cans of air for cleaning off computer keyboards. Sounds like something from Viz
Mr Sam Posted February 27, 2007 Report Posted February 27, 2007 i had the same problem with one of my rear suspension nuts in the end i got fed up and took it off with a grinder and nicked a spare nut and bolt off the other car
X-pack-Glyn Posted February 27, 2007 Author Report Posted February 27, 2007 Got it off and saved the bolt. cut the eye of the leaf off, then bush outer sleeve, rubber bush then run a grinder along the inner sleeve, took bloody hours but saved £3 on a new bolt!!!
jay Posted February 28, 2007 Report Posted February 28, 2007 Got it off and saved the bolt. cut the eye of the leaf off, then bush outer sleeve, rubber bush then run a grinder along the inner sleeve, took bloody hours but saved £3 on a new bolt!!! was it one of those 'i'm doing it my way' moments
