chinkamon Posted May 15, 2017 Report Posted May 15, 2017 hi all so the mk1 tina is running beautifully now I'm happy to report how ever as I was gunning it down the road I suddenly thought is the oil levels ok?!?! they were luckily but I've only changed engine oil since owning the car as levels as have been fine in axle and gear box but is it something g that's maybe worth draining and replacing if so any suggestions on the best to replace it with
colr6 Posted May 15, 2017 Report Posted May 15, 2017 Don't think you can do either without sucking it out. Can't Rember if there is a drain plug on the box. I would use ep80/90 in both
chinkamon Posted May 15, 2017 Author Report Posted May 15, 2017 pretty sure there's one on the box yea, I have a syphon that I use in work which is designed for oils was thinking maybe use that?
chinkamon Posted May 15, 2017 Author Report Posted May 15, 2017 surely 54 year old oil can't be that useful anymore haha
Admin Vista Posted May 15, 2017 Admin Report Posted May 15, 2017 Do you have an LSD fitted? If so, Castrol B373
colr6 Posted May 15, 2017 Report Posted May 15, 2017 surely 54 year old oil can't be that useful anymore haha They don't makes things like they used to anymore.....lol 1
BeigeAl Posted May 15, 2017 Report Posted May 15, 2017 If ou have the standard 3 rail cortina box you'll need 75/90 mineral GL4 oil (do not use GL5), and for a standard rear axle an EP80/90 hypoid GL5 is what you need. I normally use Comma oils for axle and gearbox. 1
chinkamon Posted May 15, 2017 Author Report Posted May 15, 2017 If ou have the standard 3 rail cortina box you'll need 75/90 mineral GL4 oil (do not use GL5), and for a standard rear axle an EP80/90 hypoid GL5 is what you need. I normally use Comma oils for axle and gearbox. that's great thanks very much so I'm guessing wouldn't hurt to change the oil then? axle oil I just used to top up til I could feel it with my finger but never touched the gear box so any ideas how much I'd need?
Admin Vista Posted May 15, 2017 Admin Report Posted May 15, 2017 surely a 54 year old can't be that useful anymore haha You've met Col then?
BeigeAl Posted May 15, 2017 Report Posted May 15, 2017 that's great thanks very much so I'm guessing wouldn't hurt to change the oil then? axle oil I just used to top up til I could feel it with my finger but never touched the gear box so any ideas how much I'd need? 1.75 imperial pints - it's all in the manuals! They are useful - if you haven't got one now's the time! 1
colr6 Posted May 15, 2017 Report Posted May 15, 2017 You've met Col then? 54 year old .....thanks for that.....friend for life....well what's left of it! 1
Admin Vista Posted May 15, 2017 Admin Report Posted May 15, 2017 54 year old .....thanks for that.....friend for life....well what's left of it!
chinkamon Posted May 15, 2017 Author Report Posted May 15, 2017 1.75 imperial pints - it's all in the manuals! They are useful - if you haven't got one now's the time! yes I have thanks I have 2 but not at home so can't look but ill have a nose later thanks again
chinkamon Posted May 15, 2017 Author Report Posted May 15, 2017 If ou have the standard 3 rail cortina box you'll need 75/90 mineral GL4 oil (do not use GL5), and for a standard rear axle an EP80/90 hypoid GL5 is what you need. I normally use Comma oils for axle and gearbox.where do you but yours? I can only find synthetic listed
chinkamon Posted May 15, 2017 Author Report Posted May 15, 2017 ha thanks col, that's normally the last place I look haha
puddy Posted May 23, 2017 Report Posted May 23, 2017 Don't forget the oil in your steering box as well if still fitted puddy
chinkamon Posted May 24, 2017 Author Report Posted May 24, 2017 an old school mechanic said I'd get no advantage from replacing these oils specially if there's nothing wrong with it but I could do it if i was bored. I don't know if I'm that bored now hahaha
colr6 Posted May 24, 2017 Report Posted May 24, 2017 It's always advantageous to change oil. Even the so called 'long life' oils have an expiry time ! The type of oil in yours is of the type when it was thought adding sawdust to it cured a lot of things ( how times have changed) .....have you seen the price of sawdust!! Cheaper to change the oil. Your oil will be well past its sell by date .....get it changed
chinkamon Posted May 24, 2017 Author Report Posted May 24, 2017 bugger I've just ordered half a tonne of sawdust off eBay!
