Xp197777 Posted January 8, 2019 Report Posted January 8, 2019 Hi has anyone got or know where I can get the plastic sheet/cover that goes inside the door before the door lining goes on, need two front doors ,I’m sure there was a thread on this but I can’t find it james
Moderator Rally Pack 2000 Posted January 8, 2019 Moderator Report Posted January 8, 2019 I ended up using Dynamat as a replacement. Because its sticks all over and has a tar layer it offered sound insulation that help stop the inner door rattles and because its so moldable that it can be pushed into the recessed areas of the door that are generally just gaps under the plastic where moisture and stuff can get into. I used the thinner version to save weight. I also used it on the floors to replace the factory tar sheets that became brittle and broke into pieces and allowed the floor to rust. A coat of Por15 paint and then the Dynamat sealed it off from further moisture.
Monza Posted January 8, 2019 Report Posted January 8, 2019 I used a roll of stair/hall carpet plastic protection. Sticky polythene!! Worked great!! Still got a roll in the garage but you're too far from me, should get some in b&q and the like....[emoji106]Sent from my SM-G900F using Tapatalk
