chinkamon Posted March 16, 2020 Report Posted March 16, 2020 Hi all So finally decided to bolt my proper GT carb on my precrossflow, however I was asked should there b a sandwich plate between the carb an the manifold, when running there's a little " flutter " and we're tryin to get it running smoothly,
katana Posted March 16, 2020 Report Posted March 16, 2020 2 hours ago, chinkamon said: Hi all So finally decided to bolt my proper GT carb on my precrossflow, however I was asked should there b a sandwich plate between the carb an the manifold, when running there's a little " flutter " and we're tryin to get it running smoothly, I don't believe so - not as std anyway. The sandwich plates were more (an attempt) to stop heat transmission from manifold to carb with water heated manifolds. 1
colr6 Posted March 16, 2020 Report Posted March 16, 2020 It’s a proper thick gasket about 8mm thick. 1
notenoughtime Posted March 21, 2020 Report Posted March 21, 2020 Normally a black plastic affair with gasket both sides 1
chinkamon Posted March 29, 2020 Author Report Posted March 29, 2020 Thank you guys, Another thing, I'm running a GT carb on a standard motor, is the mechanical fuel pump man enough? Only because I see the delivery pressures are different in my book? 1.25-2.5pounds per sq inch for standard 2.75-4.25pounds per sq inch for gt an lotus?
