Nige65 Posted November 11, 2024 Report Posted November 11, 2024 Evening all, I'm looking to replace the coolant take off fitting from the manifold on a x/flow, the existing one is rusty. I have spoken to Burton Power and they have confirmed that they don't supply this item anymore so would appreciate if anyone on here would be able to point me in the direction of a supplier. Thanks in advance.
Moderator Rally Pack 2000 Posted November 12, 2024 Moderator Report Posted November 12, 2024 I got sick of the factory alloy ones snapping off as they corroded so I went to a fluid connectors and they just sold me a brass one with a 90 degree bend in it and its always worked a charm
Miniliteman Posted November 12, 2024 Report Posted November 12, 2024 Is it a 90 degree one or a 135 degree?
Miniliteman Posted November 12, 2024 Report Posted November 12, 2024 90 degree one: (last one) https://www.ebay.co.uk/itm/126165680979
Nige65 Posted November 12, 2024 Author Report Posted November 12, 2024 The one fitted is the 135 degree type.
Miniliteman Posted November 13, 2024 Report Posted November 13, 2024 135 degree type on ebay https://www.ebay.co.uk/itm/176508792514
Nige65 Posted November 14, 2024 Author Report Posted November 14, 2024 21 hours ago, Miniliteman said: 135 degree type on ebay https://www.ebay.co.uk/itm/176508792514 Thanks for the link, I can’t believe that price! I managed to remove the corrosion and clean the fitting up to a satisfactory standard, the aluminium under the corrosion was pretty sound so saved a few pounds there 👍 1
