When driving i periodocally getting a noise that comes from the rear wheels area. A sort of dum dum dum noise. Almost as if the wheel is rubbing on something as it goes round. Gets faster as i drive faster. Maybe bearings..... Not really sure. Any ideas or checks i can do. Thanks.
Not particularly expensive, but unless you have the right tools it's probably a garage job to remove and fit new ones
I've just had the bearings replaced on a driveshaft on my van today. The bearings cost £8. Took 15 mins to get the shaft removed, I took it down to the local garage who have a hydraulic press. They removed the old one and pressed the new one into place. And charged me nothing!
I think I have established that it is wheel bearings. Where cn i get them from and quick, need on and fitted before Brands track day. Mine is a 3.0 litre but in a 1.6 lazer shell, mk 3. Satndard rear wheels, axle etc. Please any help with web links or phone numbers would be great , thanks.
I don't want to pee on your bonfire mate, but if it is the rear bearings, they might not be that cheap.
I had one of mine go a short while ago. Normally, I do everything myself, but the rear bearings on the Capri have to be pressed on at something in the region of 20 ton :shock:
The hard work is getting the old ones off... they have to be very carfully removed with a grinder. I took mine to Tickover in Bexleyheath, but before the car went in, I asked them if they needed the car, or could I just drop the halfshaft down to them.
Their reply was, "You may as well bring the car in, we will only charge you an extra fiver to remove and refit the shaft!" Total bill was £55 :wink:
I had a noise (like a whining) from the back of mine last week.
I got out, threw the daughter out and not heard it since!
PMSL :lol:
Paul the bearings are still obtainable from your local motorfactors all day long mate: Quinton Hazell Part No. QWB151C all models 10/1980 onwards.
They ain't easy to get off and as said previously they need to be pressed on so probably best left to yer local garage....
I am now not so sure it is the bearings, maybe thinking it's the diff.
Jacked the car up and rocked wheel but no movement so thinking maybe not bearings. Bro in law thought maybe the diff.
Jacked up car again and started engine. Got in, took off handbrake and pulled off in first gear. One wheel spinned very freely and quick where as the other was almost stopping and juddering. Is this normal with an open diff?
Tried on bro in laws open diff volvo and both wheels spinning quick and free.
This is bothering me now and only ten days till brands hatch to sort.
If it is a diff needed how much for a new open diff.
Thanks guys for your help on this.
is the noise evident when under power or all the time?
If it is the first then its the diff. It it is the latter then it should be the bearings. Can't be 100% on that without hearing it but it has always worked for me.
I agree that the bearings are available from most motor factors - I think I paid £18 each. Getting the half shafts out canm be a lottery. They either pop out or they don't. If you have a slide hammer ready your halfway there. Once out find yourself a friendly garage (???) with a press. They can press the old ones off and press the new ones on - cost me a tenner for a beer.
Only problem may be that if the race has come adrift it can get stuck/welded to the halfshaft and can mark it - that's when it gets difficult to get them out. When you eventually get them out I cleaned mine up with a bit of wet'n'dry.
Good luck
It is most of the time but not always. As I accelerate it gets faster with the speed of the car. Is a new open diff expensive?
sounds like the bearings not te diff
You normally get more noise from the diff when you boot it or slow up - do you get a lot more noise on over-run as you bak of the loud pedal?
It tends to get a little louder as i accelerate and also increases in speed as i speed up, ie in time with the speed of the wheels. What about the test i did with the wheels up going in first gear but one quicker than the other???
Thanks Chris. I think so too. Just been out again and its the noise all the time, even when i dip the clutch or coast in neutral. Cheers mate.
If I get it fixed in time I will be there. All depends on finding the bearings quick and a grage that can do it, finger crossed!!!
Call me when you are there on the sunday, good to meet up. Mobile number sent by PM.
Cheers, Paul.
