adam.wilkinson Posted June 5, 2007 Report Posted June 5, 2007 Hi all, the only thing that is stopping me getting my car back on the road is the cuffin gearbox mount! I have just converted my Capri from a 4 speed to a 5 speed type-9 and gearbox mount it well off!!! Anyone any ideas as to what i need??? Thanks
Guest cortinamad-gonetoo Posted June 5, 2007 Report Posted June 5, 2007 if its similar to mk2 escorts just weld soime 2x1 tubing on to the bracket and bolt it through the floor pans it might sound bodgy but 1 it works and 2 alot of people do it either temporally or just leave it like that all depends on how concours you want it
Admin Vista Posted June 5, 2007 Admin Report Posted June 5, 2007 As said, extend the brackets back similar to this, this is how it looks under my mk1 escort, but my mk1 3 litre capri was achieved in an almost identical fashion
Tom Posted June 5, 2007 Report Posted June 5, 2007 or use a sierra mount and go through the floor mate
Admin Vista Posted June 5, 2007 Admin Report Posted June 5, 2007 or use a sierra mount and go through the floor mate Nooooooooooooooooooooooooo a lesson from ACME school of Bodgit and Scarper as taught by Wiley Coyote
CéDriC Posted June 5, 2007 Report Posted June 5, 2007 or use a sierra mount and go through the floor mate Nooooooooooooooooooooooooo a lesson from ACME school of Bodgit and Scarper as taught by Wiley Coyote Why not cut the original mount, and weld them further back.
Admin Vista Posted June 5, 2007 Admin Report Posted June 5, 2007 or use a sierra mount and go through the floor mate Nooooooooooooooooooooooooo a lesson from ACME school of Bodgit and Scarper as taught by Wiley Coyote Why not cut the original mount, and weld them further back. By mount we mean the crossmember that is secured to the gearbox, I'm assuming you're meaning the mounting points in the tunnel? I have seen this done but to be honest it's easier just to extend the brackets or as Tom suggested, drill through the floor yeeeeehaw!
Noodles Posted June 5, 2007 Report Posted June 5, 2007 If yer gonna go wild west and go though the floor might be an idea to strengthen were mounts bolt I sandwiched the floor between some thick steel. But it all depends how neat you want the job.
emu Posted June 5, 2007 Report Posted June 5, 2007 or use a sierra mount and go through the floor mate Nooooooooooooooooooooooooo a lesson from ACME school of Bodgit and Scarper as taught by Wiley Coyote Practicality before prettiness . Just watch the reduced ground clearance or you could well snap the mounting boss off the tail end of your gearbox
Admin Vista Posted June 5, 2007 Admin Report Posted June 5, 2007 It's not that it's not pretty it's more that the floor doesn't have much strength in that plane unless you reinforce it.
emu Posted June 5, 2007 Report Posted June 5, 2007 It's not that it's not pretty it's more that the floor doesn't have much strength in that plane unless you reinforce it. Got ya Mines got a plate on the inside and the outside to beef it up. Like I say, it broke the box rather than the mount when I grounded it out so itseems ok. In all fairness,it was suppose to be temporary just to get the car up and running (I wouldnt weld when I put in the pinto so had to make it a total bolt-in job) but works well enough that I cant be bothered to change it If I was to do it again then I would weld in new mounts. If only for the extra clearance and to save scrabbling around under the carpet to hold the bolts when dropping the gearbox out.
Noodles Posted June 5, 2007 Report Posted June 5, 2007 My bolts were welded and flushed so nothing pokes out inside
emu Posted June 5, 2007 Report Posted June 5, 2007 My bolts were welded and flushed so nothing pokes out inside Ive only just regained the courage to go anywhere near my car a welder Will have to Splodge the bolts next time the carpet is up.
Jay_harrier Posted June 5, 2007 Report Posted June 5, 2007 or use a sierra mount and go through the floor mate Nooooooooooooooooooooooooo a lesson from ACME school of Bodgit and Scarper as taught by Wiley Coyote Why not cut the original mount, and weld them further back. This method is the neatest, extending the mounts with tube doesn't look mechanically sound as you've just added a lever into the mix. Although bolting through the floor sounds cowboy, if you weld a thickener plate with captive nuts on the inside then this is would be ok too. Best option is to move/buy/make mounts & weld them in the correct position.
adam.wilkinson Posted June 5, 2007 Author Report Posted June 5, 2007 Cheers for all your replies guys!!! Will have a look this weekend and see what i can come up with!!! Thanks
Tom Posted June 6, 2007 Report Posted June 6, 2007 It's not that it's not pretty it's more that the floor doesn't have much strength in that plane unless you reinforce it. you're right but, to be fair, there isn't a great deal of weight pulling down on the floor. Some big (and i mean big) washers will be just fine. i don't think its a cowboy way of doing it, just easier if you can't weld or are working on your back with a jack and a rope
crapichris Posted June 6, 2007 Report Posted June 6, 2007 I bought some angle iron, welded it to the existing mount to extend the reach and drilled the angle iron in line with the existing gearbox mount holes. Been there 3 years now and it ain't fallen off yet. The proper option is to grind off the existing mount move them back to line up with the gbox and re-weld them back. Choice is yours mate
Rick Posted June 6, 2007 Report Posted June 6, 2007 cant you unpick the proper mounts from the right car bolt them in place and weld them to the inside of the tunnel ??
