howdy, on the wekend i picked up a job lot of parts, this included a 1700 711m block and a set of weber dcoe carbs. and i got some +90 pistons, :twisted: . so i am building an engine, i will try to get some pics up but my plans are this-
1700 block honed and crosshatched
+90 pistons
steel rods
whole engine balanced
stage 3 head done by specialized engines
twin dcoe's
vernier pulleys
and timed proplerly!
and many more.
my problem is what cam do i chose? i have a coice a kent 244 or a piper 285. steve at track and road says piper and iam at se says kent. loads of people use kent cams but i hear the lobes go to quickly? is this rue i need help(btw dad says kent) :lol:
so help! :oops::lol:
gav
I spoke to Cat Cams the other day - he recomended one of their grinds. they had just replaced a Kent 234 and had made more power and Torque lower down the rev's - might be worth putting in the pot too!!
I loved Kent's 234 I had in my crossflow. What Pistons 1300 or 1600 cos all of these cams will work better with a bit extra compression from the 1300 (smaller bowl) pistons. The wilder you go the more compression you need.
I've heard Kent for power, piper for torque.
i have a piper cam in my pinto, its a beast when it comes in!! doin 40 in 4th knock it to 2nd and it spins the wheels, not a clue what they are like for x-flows though
toby gonna pm you matey! :wink:
Piper 285 is excellent fast road cam, I had one and it was great :thumbsup:
i dunno what to do. shall i wait, and also toby replie to my pm :lol::beer:
I've also used the 244, that was great too :lol:
ahh im seriously confused!this is worse then adolesance :lol:
think i just have to see what other people say about the cams !
The Piper 285 was an excellent fast road cam with good power/torque low down and my Kent 244 was deffinatly much more powerful up the top end of the rev range and slightly less happy at low revs.
I'd go with whatever Toby reccomends, if you don't like the cam then you can blame him :mrgreen:
thats the one i have in my pinto, awesome cam!!
had an fr32 in my old engine, much prefer the piper
+90 pistons
steel rods
twin dcoe's
vernier pulleys
and many more.
nicce plan :twisted::thumbsup: , whats it going in ?
btw, where you going to get the steel rods? im going to get steel rods nd pistons for mine (once ive saved a bit more up lol :lol:) and the only place i know to get steel con rods (if thats wat you ment) is burton, which cost approx £700
also check out the resto ive started on my ported head http://www.oldskoolford.co.uk/phpBB2/vi ... 595#800595
just need some better pic's
Just out of intrest is there any companys out there that make custom grind cams for pinto and crossflow. I here pinto likes lots of lift but not too much duration duno about crossflow though. Would be good if u could design your own one off cam.
Most companys will grind a cam for you if you show them the money but there must be 50 different profiles out there for the crossflow and there is normally one that fits the bill :thumbsup:
I've got an A2 in my Pre Crossflow. It's meant to be an easy to live with Fast Road cam which comes in at 3000 RPM and lasts till 7000 RPM. I can't tell you what it's like though because I haven't had it running for long enough :roll:
But that said, Johnnyh took me for a spin in his Mk1 Escort which has a 1600 Crossflow on twin side-draught Webers and an A2 camshaft. It wasn't slow thats for sure... it pulled like a train and went like a bullet! :shock:
I beliece SPC (Sussex Performance cars) in Horsham do cheap steel rods.
All engines benifit from the fastest valve lift possible (with a reasonable cam life), the faster you can open the valves the more the engine can breath within the allotted time (duration), this makes the engine more like a 16v which as we all know (but wont admit :lol:) are better breathing than an 8 valve.
A bcf3 and an A2 is dated in it's valve opening and therefore, unless there is a reason not to (already have one) I would always pick a 234 or 244 over one of these.
All the power is in the head so make sure that is special!! :thumbsup:
wow there cheap lol! £465 +VAT for rods edit: damm 'Min order 16 rods'
£895 crank 8)
thanks m8 :)
+90 pistons
steel rods
twin dcoe's
vernier pulleys
and many more.
lol its goin in nothing yet gonna build a mean xflow and put it in an osf which turns up! :wink:
£895 crank 8)
thanks m8 :)
Have a look on E-bay for the steel rods and cranks as both SPC and IkEngineering sell on there and they're the same.
I bought mine off IkEngineering and they're top quality,fantastic engineering.Made in the US I believe so why they are so cheap compared tp British ones.
http://stores.ebay.co.uk/I-K-Engineerin ... 18Q2el1247
To keep on topic I would reccomend a Holbay R120 cam, real torquey.
thanks, and sorry youngosf (is it gav?) :oops:
I think they're cheap cos they're not made in America :wink: But if they work - who cares - except the western engineers! :sad:
