FredTransit Posted June 9, 2008 Report Posted June 9, 2008 Red diesel is the same as white in quality, it has a chemical marker that is detected by the ministry if you are dipped on the public roads. It's legal for off road use only, and you may not be able to explain away the presence of the marker in your tank if you are on the public highway. You can't use the car on the public roads if it's had red in it, you are supposed to wash every bit of evidence you have used it before going back to the road from the private land you have legally used the red on. Veg oil is now legal to use up to 2500L per year now, as already mentioned. If built a car only for the strip, there should be no reason you can't use red in it.
TwoLitrePinto Posted June 9, 2008 Report Posted June 9, 2008 Veg oil is now legal to use up to 2500L per year now, as already mentioned. ahh, i wondered why i saw a bloke walk out of tescos with a trolley full of nothing but cooking oil! thing is when i went and looked, even vegetable oil is 80 something pence per litre i think... still better than £1.20+
X-pack-Glyn Posted June 9, 2008 Author Report Posted June 9, 2008 Interesting..... so a 330D engine would run on red ok then?
badchild Posted June 9, 2008 Report Posted June 9, 2008 Yeah im with Fredtransit on this one, red is every bit as good if not better than white, it is purer diesel, but id say the staining is an old wives tale, at the worst i would imagine it would make your fuel filter element pink. Theres a place by us is doing white diesel the same price as red everywhere else lol They have a cube in the back of a battered old van and they fill up from that, fookin good diesel too, its just brought across the border
allanmex Posted June 9, 2008 Report Posted June 9, 2008 Just remember, if you're running your strip diesel on chip fat, make sure it's got a BOSCH fuel pump, cuz they're the only ones that'll cope with it so I've read. ive heard that too, but ive been running my old pug 306 on veg oil for ages with a lucas pump with no probs at all, in fact i think it runs better than diesel
hotrodholty Posted June 10, 2008 Report Posted June 10, 2008 can i just throw a coouple of gallons of asda's finest veg oil in my vw 1.9tdi t4 van then and it will work ok?
FredTransit Posted June 10, 2008 Report Posted June 10, 2008 can i just throw a coouple of gallons of asda's finest veg oil in my vw 1.9tdi t4 van then and it will work ok? Possibly. What make of pump have you got?
hotrodholty Posted June 10, 2008 Report Posted June 10, 2008 can i just throw a coouple of gallons of asda's finest veg oil in my vw 1.9tdi t4 van then and it will work ok? Possibly. What make of pump have you got? dunno to be honest, what do i need? would it be ok mixed oil and diesel
X-pack-Glyn Posted June 10, 2008 Author Report Posted June 10, 2008 im not really worried about the veg oil thing TBH.... But we are all agreed that red is ok for the strip then?
FredTransit Posted June 10, 2008 Report Posted June 10, 2008 im not really worried about the veg oil thing TBH.... But we are all agreed that red is ok for the strip then? Yes, but on no circumstances take the car on the road after. can i just throw a coouple of gallons of asda's finest veg oil in my vw 1.9tdi t4 van then and it will work ok? Possibly. What make of pump have you got? dunno to be honest, what do i need? would it be ok mixed oil and diesel As long as you have a Bosch pump, the lucas can't take it as the seals don't tolerate the veg oil.
bortaf Posted June 10, 2008 Report Posted June 10, 2008 New veg oil has a higher calorific value than diesel so it burns hotter and you get more power, used really needs the soaps removing (produced in the re-heating and cooling process IE cooking) by adding hydrogen peroxide and then washing with water, using neat USED cooking oil is NOT the best option, power wise Also used oil has less lunbication propertys hense not using it in a lucas pump although i run the wifes lucas pumped escort on 1/2 and 1/2 thats only cos i use NEW oil. Red is the old high sulpher diesel we used to get at the pumps and actually runs better in older engines that where designed to run on it (Di and LR ect), kitty litter does NOT work the only way to get rid of the dye is to use acid to neutralise it but then that ruins the pump seals Been there, tried it, bought the new pump
FredTransit Posted June 10, 2008 Report Posted June 10, 2008 Sod it I am trying the used stuff, filtered and settled. By soaps do you mean the tallow (animal fat) that settles as an opaque scum at the bottom? Can't be doing with the washing or other chemistry lesson stuff, which is the same reason I won't be going on to making biodiesel. We mix it 50/50 with diesel so effectively it's halving the diesel bill. New oil isn't that much of a saving to try it as far as I am concerned. Netto was the cheapest I could see, and that's still 90p per litre I understand we can do a higher percentage, and next I am going to try acetone with it.
ratman Posted June 11, 2008 Report Posted June 11, 2008 but id say the staining is an old wives tale, at the worst i would imagine it would make your fuel filter element pink. I had a pug 206D and when i serviced it the fuel filter was pink said to the guy i got it off been running ribena have we he just smiled and went as pink as the filter
john_3.0s Posted June 11, 2008 Report Posted June 11, 2008 so can i sling 50% sunflower oil into my 51 plate tddi mondeo? its got a load of electrical gubbins on it (way more than my old td mondeo).... b*gger about red diesel prices coming up, my old man uses it in his canal boat. Thieving treasuary scum.
bortaf Posted June 11, 2008 Report Posted June 11, 2008 newer diesel dont like the extra viscosaty of oil beest check on the mondeo forum for that IMHO, i don't really mess with new cars
FredTransit Posted June 11, 2008 Report Posted June 11, 2008 Macros Fred £14.75 for 20 L is that including VAT? Cos Macro has a nasty habit of displaying prices ex VAT. Anyway, back of certain restaurants = FREE!
bortaf Posted June 11, 2008 Report Posted June 11, 2008 No tax on un cooked food stuff i believe, got some today 17.45 for 20l, bloody gone up as well
walshe Posted June 11, 2008 Report Posted June 11, 2008 afaik you cannot use anything but diesel in newer mondeos passats etc something to do with them being commonrail injection as apposed to indirect injection i think. they get quite upset if anything other than straight diesel is used in some instances will not start or run at all
FredTransit Posted June 11, 2008 Report Posted June 11, 2008 No tax on un cooked food stuff i believe, got some today 17.45 for 20l, bloody gone up as well 87.25 a litre, stuff that I would go for free any time, even macro is not a huge saving.
bortaf Posted June 12, 2008 Report Posted June 12, 2008 40p is enough for me and i get more MPG with the mix as well
FredTransit Posted June 13, 2008 Report Posted June 13, 2008 Gonna get Gary to see how much veg is in France when he goes next.
FredTransit Posted June 14, 2008 Report Posted June 14, 2008 You pay the French VAT on it, it's legal. Sod the wine, we will bring back veg oil....
