A couple of weeks ago 105steve on here asked us to refurb his crossflow head and give him some more power,
bring it over Steve we,ll gladly do it i said , so he drops it off
straight in the degreasing tank for this one :D
so out of the tank and time to check it over , remove the valves and lets give it lacqur crack test ,
hmmm sorry Steve 4 cracks ,1 really nasty , let me look in our parts department (my shed :D ) see what i got to help him out with and as i thought a nice head for him needs refurb but saves us hunting another,
so first up is clean and a surface skim
now Steves old valves cant be used as the stem sizes are different , so lets get porting whilst Joe sorts some new valves as he,s finished his daily work early
all looking good there , now i know i already previously fitted unleaded seats so just need to re cut
all done time to grind the valves in now
all done and looking good
seals and springs next
and i pinned and matched his manifold if you look closley you can see the pins either end
new studs and big bore exhaust gaskets
and a phone call today to Steve to say its ready and lucky enough its his day off tomorrow so coming over to collect , i also supplied him with a new head gasket , happy days ,
now i,m going to reface his old valves and keep them as they are in good condition for another head that needs bigger guides
hope you liked that insight to a head overhaul , call us if you would like yours done :thumbsup:
very nice Col.
It may be the way the light is shining on them but the old valve in the last photo appears to have a flat face whereas the new ones are slightly concave. Can you tell me what the difference is please?
Well Scott as far as i know it was for weight saving , those domed faced valves weigh less than the flat ones and to achieve this they take material off the face with the minimum loss of c/r , that,s what i think but i may be wrong :thumbsup::thumbsup:
:thumbsup: I thought maybe you'd scalloped them to adjust the compression ratio or something but they come new like that? Are all new X -flow valves like that or just that particular manufacturer?
Well Scott i,ve got 3 sets of crossflow valves in the workshop and all have different base,s , i think it is down to manufacturer but i,ll get this confirmed cos as i said to be honest i,m not 100% sure , i did a Renault Clio before xmas with cambelt failure that needed 3 valves and the new ones that were supplied by the motor factors we use had different base,s to the original,s but when all assembled and refitted ran perfect :thumbsup:
Cheers Col, I am well happy with what you've done, looking forward to getting it fitted this weekend. I took your advice and polished the manifold up and it looks the business, I'll get some pic up soon.
I'd recommend you guys overtime :thumbsup:
  • 1 month later...
