BIGKEV Posted February 9, 2007 Report Posted February 9, 2007 So whats gonna happen when fuel supplies run out - will it all turn out like Mad Max?? Discuss
Cookie Posted February 9, 2007 Report Posted February 9, 2007 If it does we need to stick together as the OSF crew and make sure we are the Daddies, to keep our supplies in check , maybe take over a big industrial estate as our fortified base
over_head_cam Posted February 9, 2007 Report Posted February 9, 2007 OSF diesels running on chip fat and methanol
Wessie Posted February 9, 2007 Report Posted February 9, 2007 im gonna start digging a big hole to bury my fuel supplys
Trevmk3 Posted February 9, 2007 Report Posted February 9, 2007 mad max style of life sounds good you'll get all the governments saying thet they told us it would all run out, but they will have a huge stash of it . people will start to find out where it is and plans to take over the areas of fuel storage will start or something like that anyway
Gonzo Posted February 9, 2007 Report Posted February 9, 2007 storing it's not gonna work cuz fuel goes flat. wo't matter how much you have then if it won't run yer car. diesels are the only sensible way to go really, or nasa could actually manufacture the hydrogen engine they've got the plans for.
ratman Posted February 9, 2007 Report Posted February 9, 2007 Every man and his dingo will be after the fule just hope Tina bloody turner don’t end up in charge and sing
DeuceCoupe Posted February 10, 2007 Report Posted February 10, 2007 it would be good if theres someone like mel gibson
Slik 50 Posted February 10, 2007 Report Posted February 10, 2007 storing it's not gonna work cuz fuel goes flat. wo't matter how much you have then if it won't run yer car. diesels are the only sensible way to go really, or nasa could actually manufacture the hydrogen engine they've got the plans for. GM are suposadly doing a big consumer test on hydrogen vehicles this year. Apparently the have refineing the technology for the past 7 years or so. http://www.gm.com/company/gmability/adv ... 91806.html
Johnson Posted February 10, 2007 Report Posted February 10, 2007 Mad max style future??? that means shovelling pig shit, no thanks. il just run mine on alcohol
Gonzo Posted February 10, 2007 Report Posted February 10, 2007 ford might manufacture their ceramic engine if that comes to it. apparrently they ran it flat-out 24/7 for years using water for lubrication, then pulled it apart to find almost no wear on the engine at all! ...so of course, they sat on that idea straight away.
Admin Vista Posted February 10, 2007 Admin Report Posted February 10, 2007 It aint going to run out in our life times anyway, but will probably get scarce enough to cost a fortune. When that does happen I hope that some limit is placed on people who use huge amounts of fuel for their own personal amusement, owners of private yachts and jets for instance.
