driving my car last night. on the way to pompy all was good but on the way back with lights on wipers and ellecy fan oh radio as well. the alternator guage had come down to half way. is this normal. the car is running a sierra p100 alt and standard battery (only one i could fit on the tray). so would it help fitting a bigger battrey or does it sound like the alternator is up the swany :?:
Sounds like you could use a higher output alternator.
A bigger battery won't make a lot of difference when the car's running, it's the alternator that is trying to power all of the accessories as well as trying to charge the battery.
Not sure what output a P100 Alternator would have, but it must be worth stepping up to an 85amp jobbie.
Have you got a multi-meter mate??? If so, test the battery with the engine switched off. The voltage should be just over 12 volts (normally about 12.5)
Next with the engine running, do the same test. Do this on idle and then fast idle. The voltage should be between 13.8 %& 14.2 volts respectivley.
Don't forget to check your electrolyte levels in the battery, but as we have just had a cold spell, I would be inclined to say the battery may have had it. I don't have much luck with batteries personally, and they always seem to die in winter.
Try those tests and see what happens :wink:
Yes, but that will only tell you if the alternator is charging without load. Quite often one of the diode packs will go down (they usually have three) which won't show up on thiis test.
Try turning the headlamps on to full, the fan on, the wipers on, the radio on and anything else you may have. Let the battery voltage drop for a while and then rev the engine up to 3K or more. If the alternator is OK then the battery voltage should stabilise and then start to creep up, of the alternator's f*cked (or the output is too low for the demand) then it will continue to drop.
mate dont worry, the guage is proberly not accurate, how old is it?? :D:D
Ive never had any problems mate, when you have everything on its gunna draw current, it still starts ok dont it?
I run a P100 alternator on mine too, from memory they're 55Amp as opposed to the Standard 36Amp. Mine sits about half way across the gauge and I've never had any problems. An 85 Amp alternator as proposed earlier would be nice but ultimately is probably overkill for what little electrics a mk1 has. My 55Amp one copes fine with all the extras I have like Cibies, audio etc.
thats nothing, my green RS goes into the red mate, :D
Likewise.. Except my charge light comes on? This happen with yours Baz?
no i dont get that mate, but i wouldnt worry :D
