crapichris Posted February 12, 2016 Report Posted February 12, 2016 anyone have any idea where I can get the 3 ancillary water hoses for a pinto powered Capri. These are the ones that go from the heater to the engine, the heater to the auto choke on the carb, and the one from the auto choke on the carb to the manifold. Mine are getting a wee bit crusty and I am struggling to find replacements. Have mananged to slvage one that burst but it ain't ideal.
mk1del Posted February 13, 2016 Report Posted February 13, 2016 have you thought about silicone hose kit ,can get them in black
classicwhitey Posted February 14, 2016 Report Posted February 14, 2016 capri club international do them i believe
crapichris Posted February 14, 2016 Author Report Posted February 14, 2016 Thanks for the responses. The silicone sets I have seen are £100+ which seems ott.I did ring the CCI last year but they didn't have the ancillary pipes I am really after. Been taking risks with the 2 carb hoses but as my daughter wants me to deliver her to the church for her wedding and I have to drive down to Kent to deliver I really don't want to play silly buggers on the M25.
katana Posted February 14, 2016 Report Posted February 14, 2016 Do they have to be the exact / correct hoses? Can't you just use ordinary straight heater hose - point A to Point B style?
mk1del Posted February 14, 2016 Report Posted February 14, 2016 I got a set from rally design for £55 for my rs
robert maguire Posted February 14, 2016 Report Posted February 14, 2016 I have set used, from Rs2000 mk2 escort incl rad hoses .For sale .
crapichris Posted February 14, 2016 Author Report Posted February 14, 2016 Sorry you can't use the straight stock hose as their a couple of right angle bends. Tried it once, one of the hoses closed and I was forced to make an emergency pit stop to relieve the constriction. Hence I am back using the old hoses
crapichris Posted February 14, 2016 Author Report Posted February 14, 2016 Just looked at the rally design kit. As its for an escort will the pipes be long enough,particularly the heater to carb hose?
mk1del Posted February 14, 2016 Report Posted February 14, 2016 Not sure, but if you ring them I'm sure they could help you, measurement etc.
katana Posted February 15, 2016 Report Posted February 15, 2016 Sorry you can't use the straight stock hose as their a couple of right angle bends. Tried it once, one of the hoses closed and I was forced to make an emergency pit stop to relieve the constriction. Hence I am back using the old hoses Yes there are if you try to follow exactly the stock route, my plan was find a longer route to avoid kinking the hoses - may not look stock but if it gets you on the road whilst you source correct bits ...........?
classicwhitey Posted February 15, 2016 Report Posted February 15, 2016 other option could be to use sections of straight standard hose and use alloy joiners/ elbows for the bends?
Tackleberry Posted February 16, 2016 Report Posted February 16, 2016 I bought the silicone set for my Capri, finishes it off lovely...plus, the £100 you spend will be a lot cheaper than getting yours recovered if they go pop...and the upset it would cause on your daughters big day. See it as an investment mate.
Admin Mk2Jo Posted February 16, 2016 Admin Report Posted February 16, 2016 The silicone hoses will last a lot longer than the std hoses as they don't perish like the std ones
HotRodMatt Posted February 17, 2016 Report Posted February 17, 2016 Plus they are available in a more classic appropriate matt black, albeit for £20 more than a standard silicone colour.
colr6 Posted February 17, 2016 Report Posted February 17, 2016 Airtec the rad people. ancillary hose kit £55, just got a set for my cossy in black look quite decent
crapichris Posted February 20, 2016 Author Report Posted February 20, 2016 Phoned rally design but they couldn't confirm that the rs2000 ancillary pipes were the same as the Capri. So have gone for the Tickover kit instead which is dearer but know will fit. Let you know how I get on. 1
crapichris Posted February 28, 2016 Author Report Posted February 28, 2016 Pipes now fitted and system running OK. The pipe from the heater to autochoke seems to be at a slightly different angle or twist to the original so needed a fair bit of playing with to get it at the right angle otherwise great. Recommended. 3
HotRodMatt Posted February 28, 2016 Report Posted February 28, 2016 Glad you got it sorted. It's the smaller bits that are the most annoying sometimes! Always good when someone updates a solution in their thread too. [emoji106]
