Hi all
So after a load of unexpected bills have hit the floor my paint the car fund has vanished
So now can't paint it for a while
Problem is I removed the wing mirrors from the wings an relocated on to the doors
Filled the holes and painted in what halfords said was the same colour...but it's obviously not! It's darker
the prev owner doesn't no what colour he sprayed it as it was so long ago
No colour in halfords matches ( 1 did but it isn't the same??! )
So now I have 2 splodges of darker paint on the wings, unable to afford to spray the whole car. What's my best options? Don't really want to leave dark splodges on the wings but don't know how to proceed from here?!
Do I leave it, rub it back and leave it in primer/ filler?
What would you do
There are paint suppliers who can find the right colour with a machine and make up an earosol for you. Can't remember what they call the machine. Had it done a couple of times and proved very effective
Yea there's only 1 round here an he's a grumpy t**t unless ur a professional buying lots of paint
Looks like I'll go see him... an bite my tongue......alot!
Cheers guys
Guessing Halfords mixed to your original paint code? As described above, you can get paint mixed up to a scan of a sample piece. Boot lid maybe? How big is the contrast though? It's not just because the original paint has faded is it?
No there's no original paint code the guy matched it to one of their colours and made an aerosol up ( as not a stocked one ) an no I used tcut on the car when I bought it hoping it would make the colour more bearable but it didn't! Never liked the colour but have to live with it til I can start saving again :(
What about one of those mobile dent repair/scratch remover chappies? Some of them paint and they may be able to mix a small amount for you.
Ken
I have a scanner ( PPG Rapid Match) and know how it works.
While scanning it measures colour spectrum at 5 different angles.
This means the scanned object should be clean and free from any debris.
Hooked back up to the computer it compares its spectrum measurements with known recipes that the manufacturer had put in the system.
Have to say not all colours are in the system. Some car factories do not give all recipes of their colours.
After scanning, a colour match 1 to 7 is good and most of the time hardly noticeable.
Match 7-10 is acceptable in most cases. Any match above 10 is not preferred.
The computer tells the operator in witch way the new colour will differ, redder or greener or darker or lighter or more flop, less flop etcetera etcetera.
A well trained operator will be able to correct the recipe to a perfect match. That's an expensive training that Ill have to follow this year and Ill suspect no Halfrauds bloke will do.
I have scanned my own Capri and end up with a match 24 meaning nothing comes close ( meaning the bloke who did my car few years back messed up the paint recipe as I know what it should be when I told him to).
If scanning is not working the next step is sending a piece of the car to the paint laboratory of the paint supplier where they are able to make a recipe to match your car. But that's expensive.
Wow that sounds complicated and very clever!! So how big does the bit need to be for the scanner? I found another new place locally I'm going to try Monday but I was going to take a 50p sized chunk that's peeled off from inside the door?
2" by 2" flat surface is preferred for measurement.
Slightly smaller can work but needs to be exactly in front of the scanners lens.
I have made good scans from the Genuine '70's Ford Colour exterior & interior book samples which are about that size.
