Im looking for a good 12 or 13 inch fan to sit at the engine side , so a puller. I was told a Pacet profan was a good un , but know if the company still exists , any recommendations ?
Thanks for the replys ill have a look at Revotec , and your right enough colr6 the temp was fine on the motorway the I went the cooler the temp , just when I came into traffic it began to creep up .
No problem.
If you can only get a 12" one in then also consider a pair of 9" ones side by side as the two 9" ones will cover a greater cross sectional area of the radiator. A 13" one on its own however will be larger than a pair of 9" ones. Personally I like to use a pair as it gives redundancy of one fails.
