On that big bulb heater housing on bulk head there is a big hole in it just behind rocker cover. I am sure there is a moulding that goes in the hole. Any idea what it is called and where I can get one
  • Moderator
The plenum chamber drain tube has a dubious reputation for retaining water and causing rust rather than draining it away. The lip of the tube is a good few mm above the metal and as such half a centimetre of water cant drain through the tube and it backs up in the plenum chamber and rusts it out. Many leave the tube out but does cause the lip to rust out more but thats easier to repair than inside the chamber so its the lesser of two evils and can be monitored. You wont become aware of plenum chamber rust until you feel water dripping on your feet or slushy carpets.
There are in fact different tubes for different engines Crossflow, Pinto and Twincam. A Twincam one sold in Australia last year for 400 pound equivalent, just for a bit of plastic. But the others are only worth a couple of quid when you see them. I dont bother with them in either of my cars.
There are in fact different tubes for different engines Crossflow, Pinto and Twincam. A Twincam one sold in Australia last year for 400 pound equivalent, just for a pit of plastic. But the others are only worth a couple of quid when you see them. I dont bother with them in either of my cars.
This, though I've never seen one fitted on a Pinto equipped mk1 over here and struggle to see how it would go in and clear the cam cover. I had one years ago and it couldn't have ever been fitted with my pinto install.
  • Moderator
I have seen two types on Pintos here actually. (Not Mk1s though as we never had Mk1 RS2000s from the factory here). One of them was a really odd shaped thing. Think of the lip in front of the Plenum chamber as a shelf. It would extend out of the hole in the chamber barely no more than the outer limit of the lip and take a 90 decree sharp turn to  the left hand side of the head till it was past the restrictions of the head against the firewall then a flattened tube came downwards over the edge of the lip. BUT and this was the problem if you had it in the plenum chamber hole turned more counter clockwise than it should it meant that the part that ran along the lip behind the head started to flow upwards and as such could back up the water in the chamber in inches instead of mm. The second type as mk1del mentions was very rudimentary which didnt hang much over the lip either but just let the water pour just behind the head. Both were rust causers though.
did you manage to find a doofer? i think i might have a spare one in the garage but wont get time to look till next week. not sure if it will fit with anything other than a crossflow though as space is tight.
i'll have a look in the garage when i get chance, they do come up on ebay though or try darren at escortec, he's got just about everything
