help with my .... um.... corsa :-D
my engines been rattling like fook for a few weeks/
what i thought was the alternator... turns out not after trying 3 different ones on it :-(
what else could it be other than the big end which im hoping its not :-(
water pump?
any help appreciated
Vauxhalls are nothing but trouble i tell ya...
get the water pump checked mate,if that lets go it will take the cam belt with it + lots of damage,bent valves ect :sad:
yeah im worried it may be that :-( will have to drive sensibly til i can have a look the weekend :roll:
Guest cortinamad-gonetoo
:wink:
when does the noise start to rumble....ie driving or just reving
:mrgreen:
never understood camebelts, if they break your engine fooks itself
cant beat a good old chain driven crossflow :-D
On a standard pinto if the belt goes it does no damage so ive heard its only when you start increasing the valve openings it will do some damage
Goes into technical blurb mode. Because there are less components involved, the engine has less mass to rotate in the course of producing power. It also leaves more room in the block for cooling passages etc as you don't need pushrod spaces. I've shamelessly poached an extract from Wikipedia and pasted it below. Plus if people changed their cambelts at the prescribed intervals there wouldn't be a problem, 9 out of 10 cambelt failures happen when people try to save money by ignoring maintenance, always a schoolboy error.
The SOHC design has less reciprocating mass than a comparable pushrod design. This can allow for higher engine speeds, which in turn will increase power output for a given torque. The cam operates the valves directly or through a rocker arm as opposed to overhead valve pushrod engines, which have tappets, long pushrods and rocker arms to transfer the movement of the lobes on the camshaft in the engine block to the valves in the cylinder head
its now more of clatter than a rattle :P
must sort it out before it turns from a clatter to a bangbang
:morons:
for all those that said water pump.
spot on! :thumbsup:
i had the cambelt cover off earlier
cam belt is slack as you like and you can see the waterpump pulley bouncing all over the place.
better order sum fresh parts tmoz :-(
hope it lasts til the weekend il let my dad help, iv never messed with camebelts before :?
thought id tackle it today all was going well although it toopk an hour to remove the allen bolt from hell
but now...
how the fooooook do you get the pump out the block, i cant budge it. iv thrown in the towel for today before i lose me rag...
i thought yep 2 hours or so il be done... hmmm
