samurai Posted November 3, 2006 Report Posted November 3, 2006 Which engine oil is best to use on my 2 litre to run in? Thanks
samurai Posted November 3, 2006 Author Report Posted November 3, 2006 Make? How many litres do i need to for the pinto? Thanks
Mark2Mark Posted November 3, 2006 Report Posted November 3, 2006 Anything cheap and thick if it is a fresh engine, it won't be in long before you change it.
samurai Posted November 3, 2006 Author Report Posted November 3, 2006 Yeah a boreing 300 miles then i can floor it
samurai Posted November 3, 2006 Author Report Posted November 3, 2006 An expensive 300 miles to should i say Them carbs drink!
Admin Vista Posted November 3, 2006 Admin Report Posted November 3, 2006 300 miles sounds a little short to me I'd go easy a bit longer than that.
samurai Posted November 3, 2006 Author Report Posted November 3, 2006 Oh poo What about Millers CSS 20w50? £29 or Valvoline VR1 Racing 20w50 £19
BaileyMex Posted November 3, 2006 Report Posted November 3, 2006 valvoline m8 thats what i use What he said
samurai Posted November 3, 2006 Author Report Posted November 3, 2006 Valvoline VR1 Racing 20w50 £19 it is then Ill order it online is it will be a pain geting it from any good shops round here! http://motorsportoils.co.uk/cart/index. ... 1741dc5975 mmm it dont say how much litre wise tho! apart from 10kg weight total.That should be enough right? Thanks
Fiesta Steve Posted November 3, 2006 Report Posted November 3, 2006 Oh poo What about Millers CSS 20w50? £29 or Valvoline VR1 Racing 20w50 £19 No m8, save that for when it's run in. These oils offer excellent protection for your engine but that isn't the idea of running an engine in. If the rings/bores aren't bedded in properly it could result in a poor engine for ever more I wouldn't pussyfoot around when running the engine in either. Don't be affraid the rev it to say 75% of its max. If anyone has ever seen an engine run-in on a dyno or on the rollers they'll know what I mean. They don't potter around with it for 500 miles they rev it quite high varying the load, gradually increasing the revs. After about an hour its at max rpm I use £2.99 asda oil for a 200 mile run-in, changed it for valvoline and drove it to Santa Pod and run a 15.0, and the engine just gets better and better! Just my opinions though, I sure lots of people with disagree with me
samurai Posted November 3, 2006 Author Report Posted November 3, 2006 Ok ive have not got it yet as i still need axle oil to! So asda oil for running in??? really? Axle oil? Engine oil for running in? Thanks
Fiesta Steve Posted November 3, 2006 Report Posted November 3, 2006 Ok ive have not got it yet as i still need axle oil to! So asda oil for running in??? really? Axle oil? Engine oil for running in? Thanks Yeah really , any normal 20/50 oil will do, just save the expensive stuff for when its run in. Still get some as you'll need it soon anyway. I use Valvoline Racing 20/50 once run-in Thank KJ, glad someone agrees with me
samurai Posted November 3, 2006 Author Report Posted November 3, 2006 So any 20/50 while running in and then a good 20/50 again when finished running in. Thanks
w p e Posted November 4, 2006 Report Posted November 4, 2006 well said mr fiesta why do 500 miles to find out if a engines gonna go bag the first time you load it up. 20mins running from new on cheap 20/50 then new oil and filter then big portions of right foot. if alls well have some fun. every engine ive ever built gets the same. no holes yet
w p e Posted November 4, 2006 Report Posted November 4, 2006 ps motos godstone rd surrey stock valvoline
samurai Posted November 6, 2006 Author Report Posted November 6, 2006 I found this engine oil today and got it for £13.99 (5litres) the only 20w50 there was
