mk1mexico Posted January 26, 2007 Report Posted January 26, 2007 I want some decent front brakes to stop my new power. They have to look the part, but im not willing to get rid of the superlites so they would have to fit under a 13 inch wheel The back brakes are 9 inch drums Discuss my options or recommendations.....
Mk 1 Mark Posted January 26, 2007 Report Posted January 26, 2007 2.8 capri calipers do the job....So do Princess 4 pots paint them up and job done Or i just bought a set of Willwood 4 pots that fit under 13" wheels from Rally design... Look the nuts but have`nt drove the car yet..Bell them or clicky http://www.raldes.co.uk/ For the rear you can use 4x4 cossy calipers and fiesta solid discs and you have discs all round
4parajon Posted January 26, 2007 Report Posted January 26, 2007 I'm personally going for the Caprisport 260 kit, which is ideal for us that want to keep our 13"ers . Have a look at the link below, Ive got 2.8 vented discs on mine, I also added braided lines to firm up the pedal feel and there still pretty poor compared to modern stopper's. Ive also been looking at a thread on Turbosport regarding Volvo 4pot calipers off a 260 which with a bit of filing out of the holes will bolt straight onto the Capri vented disc, I bet you could pick them up from the local scrappy for a tenner. Heres the link http://www.zyworld.com/caprisport/1_brakes.htm
Admin Vista Posted January 26, 2007 Admin Report Posted January 26, 2007 Cheap solution for the front I'd say is a spaced set of princess calipers mounted around Rally designs 257mm vented discs, this gets rid of the overhang problem you get from using 2.8i discs. If you're using mk 1 4 spokes the clearance between the caliper and wheel is quite tight but fits ok so your superlites should be fine. More (much more) expensive solution I guess is a set of willwood calipers.
escort21 Posted January 26, 2007 Report Posted January 26, 2007 Listen to Vista...he's right some of the time , stick on some princess calipers...made a shed load of difference on the 'tina
Rick Posted January 26, 2007 Report Posted January 26, 2007 sierra 4x4 rear disk conversion, 2.8 calipers up front would stop a train i reckon bugger but it prob wouldnt fit (shuts mouth)
escort21 Posted January 26, 2007 Report Posted January 26, 2007 No point in having rear discs unless your using really good front calipers, you'd need a bias valve to turn the back right down so its not worth the effort doing it....or forget the valve and go round in circles when you brake
Rick Posted January 26, 2007 Report Posted January 26, 2007 go right round? explain before i go fitting anything to mine? surely its like a bike you want to slow the rear down most?? :-s i dont want to set my car up to handle like a shite
escort21 Posted January 26, 2007 Report Posted January 26, 2007 Braking should be 70/30ish bias towards the front ....weight moves forward when you brake so the front wheels will have the most grip..
Mk 1 Mark Posted January 26, 2007 Report Posted January 26, 2007 No point in having rear discs unless your using really good front calipers, you'd need a bias valve to turn the back right down so its not worth the effort doing it....or forget the valve and go round in circles when you brake Well i had rear discs with the 2.8 Capri calipers bias peddle box and Front to rear adjustable, And it was perfect? Not to expensive and excellent brakes...... Im only upgraded the front brakes as i now have an all steel Xe engine going in 9" drums should be fine with Capri vented discs ect Its Just i wanted to be able to adjust the Bias for santa pod and track days ect
Rick Posted January 26, 2007 Report Posted January 26, 2007 Braking should be 70/30ish bias towards the front ....weight moves forward when you brake so the front wheels will have the most grip.. i see thanks but surely it wont cause the car to spin out or anything
Admin Vista Posted January 26, 2007 Admin Report Posted January 26, 2007 go right round? explain before i go fitting anything to mine? surely its like a bike you want to slow the rear down most?? :-s i dont want to set my car up to handle like a shite I don't understand the bike analogy, all bikes have much bigger front brakes than rear. Twin discs on the front and single at the rear in most applications, so most braking force is on the front. Escort21 is right (except when he's talking about X-flows being better than pintos of course ) most of your braking force needs to be on the front wheels, if it's the other way round you'll swap ends in hard braking.
Rick Posted January 26, 2007 Report Posted January 26, 2007 i understand the physics of the braking now but i dont understand why the car would spin around? i dont want a death trap
BIG G Posted January 26, 2007 Report Posted January 26, 2007 keep the rear drums as plenty good enough for a light escort but ive put porker boxter front brembos pn bloody fantastic calipers easy to fit as well.trouble is ive 14s but theres plenty of room i think for 13s.
Rick Posted January 26, 2007 Report Posted January 26, 2007 no not using drums theyve been binned anyway now il have to uprate upfront if i its gonna be too much a problem
escort21 Posted January 26, 2007 Report Posted January 26, 2007 look on burtons...the're called brake bias proportioning valves
Admin Vista Posted January 26, 2007 Admin Report Posted January 26, 2007 If you do end up fitting bigger brakes all round you may need to change your master cylinder too. As you'll have to push more fluid to apply the brakes (bigger / more pistons) you could end up with a really long pedal before you get any brakes.
escort21 Posted January 26, 2007 Report Posted January 26, 2007 Caprisport uses landrover master cylinders...think they are around 1"
mk1mexico Posted January 26, 2007 Author Report Posted January 26, 2007 Thought about Princess calipers but my mate has them on his RS2000, and he cant stop them squeeling and he struggles to get pads for them
V8ian Posted January 26, 2007 Report Posted January 26, 2007 Lets kill a common misconception first with Ford brakes, 2.8i Brakes WILL NOT stop the car any better than the standard set up with the same size discs, they have the same area of pad, same swept area of disc, same volume of piston as they are just spaced M16s, and will only apply the same Mechanical retardation as the same size disc. the only advantage is resistance to face due to the vented discs, The way to improve stopping power is either Better pads, more pad clamping, more area of pad or bigger discs, The first option is Vents for their cooling, then fit bigger callipers, The Princess route is well tested and works well, except for the slight pad overhang is not a problem, finding them is a problem not, another cheaper route is fit Mk2 Granada callipers, they have a lot larger area of pad compaired to the M16s, and is possibly similar to the Princess pad area, and I beleive bolt on to Metric struts, Better pad material is allways a good improvement, as long as the rest of the system is up to scratch, Rusty discs will kill a braking system, the rust will glaze the pads and will not readily wear off, start with new discs and something like EBC Greenstuff, and you will notice a improvement straight away, Bigger Discs will give you better stopping and feel but will normally need adaptor brackets to fit the callipers, Caprisport 260 set up has allways sounded good, but I think they have discontinued it in favour of another better upgrade, Another misconception, A servo will not give you better brakes, all it will do is reduce the pedal pressure and feel, servos are for GIRLIES, I have superb brakes on my Cortina without a servo, they dont owe me a fortune either, just a bit of mixing and matching + a bit of engineering thrown in, and they will pull the car to a standstill from 140+ without any fuss at all. Ian
escort21 Posted January 26, 2007 Report Posted January 26, 2007 Can we sticky what Ian said there adminy people he's dead right
Admin Vista Posted January 26, 2007 Admin Report Posted January 26, 2007 Thought about Princess calipers but my mate has them on his RS2000, and he cant stop them squeeling and he struggles to get pads for them Don't understand the squealing thing, mine never do that and the pads are readily available from rally design last time I checked. You can get around the problem of overhang that V8ian mentioned as Rally Design do a 257mm disc specifically to combat this. When compared to a set of Willwoods they are heavy, but then they aren't 3 or 4 hundred pounds either.
