Messenjah Posted February 26, 2007 Report Posted February 26, 2007 ok guys , last night i took my m8 home and stopped outside his house as he was getting out he said hold on a sec and made sure i was going to a party tonight etc and while we had this chat the car was ticking over ... then all of a sudden it stopped ... i tried starting it no joy ... i tried bump starting it no joy called out the AA he said nakered coil today i replaced the coil ... no joy so decided to make sure points gap was set properly etc and i put the car in gear and tried rocking it to set the points up (u know what i mean ) and realised the little shaft in the middle wasnt turning .. so remove the distributor itself and when i turn the gear on the bottom it does turn up at the top ... so thats not at fault but now we are getting deeper and deeper into the engine and i dont know what the problem is gonna be ... help its my daily runner how much is this gonna cost and what is it gonna be?
Messenjah Posted February 26, 2007 Author Report Posted February 26, 2007 took the cam belt cover off and when i turn the engine over the pulleys dont turn ... the crank is moving because the fan spins ... but the camshaft belt doesnt move
BIG G Posted February 26, 2007 Report Posted February 26, 2007 sounds to me like the woodruff key on the crank cam belt sprocket.take the crank pulley off and the cam belt then the small toothed pulleysee if the key has sheered
BIG G Posted February 26, 2007 Report Posted February 26, 2007 oh yeah if its the 2 litre the valves may of missed the pistons.and stop turning the engine over.
Messenjah Posted February 26, 2007 Author Report Posted February 26, 2007 i have stopped and i rang my mechanic he said u will have stripped all the teeth off the bottom of the cam belt so i stuck my head under and found one of them on the floor phew im gonna tow it up there so he can time it up for me and fir the new belt
Capripete Posted February 26, 2007 Report Posted February 26, 2007 Had the same thing on my 2.0, all looked fine with the belt, wasn't till it came off that the stripped teeth showed.
J_mk1 Posted February 26, 2007 Report Posted February 26, 2007 i have stopped and i rang my mechanic he said u will have stripped all the teeth off the bottom of the cam belt so i stuck my head under and found one of them on the floor phew im gonna tow it up there so he can time it up for me and fir the new belt Phew! ...and breathe
bortaf Posted February 27, 2007 Report Posted February 27, 2007 thats handy easy fix the belt went on me 2.0 granny last year, took 20 mins to get it all up and running again
Messenjah Posted February 27, 2007 Author Report Posted February 27, 2007 how much would u expect to pay at a garage for cambelt suply and fit and timing it back up again ?
OllieC Posted February 27, 2007 Report Posted February 27, 2007 last time i had the garage do one on a pinto it was about £50 parts and labour shouldnt be much more than that its an easy job
Messenjah Posted February 27, 2007 Author Report Posted February 27, 2007 £35 and i got the car to him after he was meant to close last night and he did it first thing this mornign despite having other jobs in ! top bloke
105Nick Posted February 27, 2007 Report Posted February 27, 2007 God that was lucky mate, I was driving my mum's corsa and the fan belt went, the AA came and changed it for me, then the following week it all went bang and clatter so I stopped it, called the AA and told them to tow me home cos the cam belt went bang - the fooking monkey insisted on starting it up before he would tow it and consequently fooked every valve and piston on the motor.
Messenjah Posted February 27, 2007 Author Report Posted February 27, 2007 timing chain went on my dads jag it went as he started it up luckily and he called the aa the guy tried repeatedly to start it causing all sorts of damage dad rang the aa and explained tht this monkey had fooked it despite dad telling him what had gone and they paid the bill luckily because it was £4k lol
Rick Posted February 27, 2007 Report Posted February 27, 2007 the fooking monkey insisted on starting it up before he would tow it and consequently fooked every valve and piston on the motor. thats the aa for ya... crossflows have chains rather than belts no worries for me
