With deep sadness due to 4 spine operations I cannot complete my pride and joy Please see my Mk 2 Escort rs2000 custom rolling shell I've own this car for 18 years.
It comes with the below items:
Carbon Fibre rear spoiler
Carbon Fibre top Dash
Spa Carbon fibre mirrors
Carbon Fibre rear window inlets
RS three spoke Steer wheel
Front clear indicators
Front 15" 7j alloys
Rear 15" 9j alloys
Ford 9" shorten rear axle and halfshalfs
Limited slipped diff
Rear brakes 2 pot hi-spec
4 link
Watts linkage
Roll cage
Rear end turreted
Gaz coilovers front and rear
World cup cross member
2.4 Ratio Escort MK2 RHD short stem steering rack
Strut Brace
Adjustable top mounts
Rear fuel tank mount
Compression struts
Large gearbox tunnel
Large axle tunnel
Exhaust tunnel
MK2 Cosworth Rad and intercooler
Poly Windows
Ex Mountune Cosworth engine (465bhp/440lb)
Lots of Carbon Fibre ( centre console, lower dash etc)
T5 Tremec gearbox (18,0000 miles)
Auto metre Gauges (speedo, tacho, volts, boost etc)
Lighten Cosworth flywheel
Ap twin plate Clutch
YB powered header tank
And misc bits and bobs
Engine Spec
• 205 block honed
• Mahle forged pistons
• Shot peened and polished rods
• 7.6.1 compression
• Cosworth bearings
• Total seal piston rings
• EN40b mountune crank fully polished (standard journal)
• Rotating assembly fully balanced
• Lightened and balanced fly wheel
• Mountune Gated and baffled big wing sump
• High pressure oil pump
• Head ported and worked to RS500 touring car spec
• Cams ground to custom profile
• 3 angle valve seats
• Bronze guides
• Inlet and exhaust ported to match head
• Swedish inlet manifold
• Shortened exhaust manifold to suit larger turbo
• Ex hill climb T4 turbo machined rear to .70 F1 shaft Sourced by Field Motorsport
• Grey injectors
• P8 Ecu
• Wasted spark
• Boreham developments Anti lag
• Field Motorsport WRC spec loom
• Machined throttle body
• WRC cam sensor
• ARP head studs and rod bolts
The spec list above does little to reflect the time and effort that has gone into this engine (especially the head) After Bob was finished Engine has been run in and mapped on the dyno By Tommy Field at Field Motorsport to which it made a conservative 465bhp and 440ftlb of torque which we agreed was plenty for a MK2 escort!
Please bear in mind these Engines are getting rarer by the day almost, and even rarer to find a turnkey example with such pedigree.
£22,500 ono (OPEN TO OFFERS)
Will split the engine and if Needed
yeah i'm very gutted but that's life I'm afraid
just need to sell her now as I she her everyday and its not nice knowing I cannot do anything
Sorry to hear of your bad fortune.
That list of goodies seems amazing, but tbh a bit, sorry, a lot over my head. Reading through the very thorough list is there anything missing or is the car ready to be put together? Also is it going to be a track only car, I noticed the rear slicks?
I am only in Rayleigh and that looks right down my street.
the car is road legal the rear slicks came with the alloys
the car is 95% ready to put back together.
items needed of my head:
front screen
Exhaust
Prop
wiring loom for car
many thanks
regards
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
Scott I’ve tried to speak to you several times regards buying it ,but you don’t seem to be bothered or you don’t really want to sell it,but good luck with the sale I’m sure it will go eventually
