I have puddles of water in my foot wells and my boot. :shock:
I think cause is poor sealing around screens. Though the rubbers look in good nick.
Do you reckon it's worth me popping out the glass and putting some new sealant in?
What sealant would you guys recommend, and is there any other sources of water you can think of?
Jim
you need to find where its coming from for sure. If the screen seal looks ok it prob is. Are you sure its not the door seals? you would be surpriesed how much water they will let in during bad weather
I got the same problem in the Capper. I think the water on mine is coming in from the door seals, both sides.
My Escort is leaking so much I'm thinking of keeping Goldfish in the boot... :lol::lol:
Depends as well if it comes in when the car is just standing, of if its when you're driving in the rain.
if it's just the seals then a decent high mod clear silicone will do it but the area has to be completely dry. if you get a lot of water in the foot wells when you are driving, check the 'A' panels, the floor pans and the bit right up under the front wings because all escorts get a bit of rot there.
Also check the windscreen wipers where they come through the scuttle.
The other place the water can get is round the wiper hole where the go through the flitch panel. Take the wiper arms off and make sure the retaining nuts are tight or put a squirt of silicone under the washers. As for the water in the boot check the rubbers round the back lights.
i had a problem with my floor pans filling up with water.
turned out to be the drainage holes in thesill were blocked and theyw ere full of water.
worth checking it out :wink:
Are you sure you have no holes in the floorpan - If you do and you are driving in the rain then dont!!
I used to be able to see the lights of oncoming cars on my knees when I had my old 4 door lol - wasnt much good metal left on it !! :shock:
All good food for thought. I'm pulling out the carpets and sound proofing this weekend. to start drying it out. Once I've got it dry in there, I'll start firing water at it from various angles.
Or I might just get a couple of fish!
Jim
They all leak don't they .... I know mine does :roll::lol::lol::lol:
Nope, mines perfectly water tight :mrgreen:
Bufty boy :lol::lol::lol::lol:
Just like Rich Sav :wink:
