I'm looking for a pair of 257mm diameter vented brake brake discs to fit my Mk3 Cortina fitted with Princess 4 pot spaced calipers, I got the last pair from Rally Design but they wont have stock for at least 8 weeks, I can get the old ones skimmed as they are a bit warped but it's not ideal, any suggestions please?
Mal, would these fit?
https://www.autodoc.co.uk/bosch/1166323
The 257 mm ones are used to make use of the all the pad area. You could use 247 mm discs which leaves a bit of pad area unused. Then fit the new 257 discs in a couple of weeks.
  • 2 weeks later...
Problem sorted, Ive had the discs skimmed which took the warp out, but for the future I have a new pair on back order from Rally Design which I now remember is where I got the current ones from, saves buying a complete new set up with calipers! besides I like the Princess ones!
