HI All,
Hopefully this will be a straight forward question, I just want to get it right before I order them! I've been sorting the rest of my car out ready for mapping and I've noticed that the track rod ends appear to have the wrong taper for the struts - the taper doesn't sit fully home in the steering arm.
I haven't measure the thread on the rack yet but I'm pretty sure its coarse UNF, which I believe makes sense being a mk1 escort (mk1 escort rack - UNF thread, mk2 escort rack - metric thread?). So being as I have Capri struts fitted, which TRE do I need? I see a lot of talk about the 'Green Rs2000' TREs, but they seem to be for metric threaded Mk2 escort racks?
Thanks for the advice as always,
Kind Regards
Joe
A pic of your thread would help, they don’t do a coarse unf thread. If it is unf then the std escort tre should fit as I’m sure they’re the same taper as Capri.
Thanks for the reply, im going to drop out later and remove a track rod end to ID the thread properly, it was a peer through the arch job!
Having looked some more though, your assumption matches others - a standard mk1 tre should fit, so if that is the case god know what I currently have fitted!
kind regards
Joe
The RS2000 rod ends are peculiar as they have a metric rack end thread but a imperial taper to suit the bolt on steering arms or its the other way around - whichever way its an oddity!
Your right in the first part, metric thread imperial taper. Commonly known as ‘green’ track rod ends although the replacements are black...lol
51 minutes ago, notenoughtime said:
I can never Remember the one you need but the rare ones are needed lol
your usual stockist won’t have them
poss try burtons or rally design
The Green TRE's for a mk2 RS2000 have an M12 metric thread to suit the mk2 rack, but an imperial taper. If the OP has a mk1 rack with an imperial thread, then standard mk1 TRE's should do the job.
Hi all, thanks for the replies and help as always! Ive just been out to check, the track rod threads are m14x2.0 and the taper on the track rod is too large for the steering arm.
So i was under the impression I needed the ‘green’ TREs from a mk2 rs2000... but @vista you mention they have an m12 thread? In which case Im still not sure...
Kind Regards
Joe
Tbh I’ve never measured the mk 2 threads just know them by sight, but I will do to confirm size. Got a few in the garage 🤭
If you have some to measure that would be outstanding! The more I investigate the more it seems I need the green track rod ends, most sources suggest they have a smaller taper than the standard mk2 TREs, and an M14x2.0 thread
Kind Regards
Joe
Sorry, my mistake. M14 is correct.
Thanks Vista, and everyone else that replied - i think that settles it then! I have a mk2 rack fitted and the previous owner used base model mk2 TREs (Ford part no.  5021411) with the capri steering arms.
I do need the green TREs (Ford part no. 1564468), as they will suit the m14x2.0 thread on the rack, and will have a smaller taper that will fit the capri steering arm.
There is a HUGE rs tax on green tres - ive seen anywhere up to £80 per side for genuine ford items, which seems insane. Instead I have a ordered a pair of firstline for £30 delivered.
Thanks again everyone, and thanks for offering ti measure some up for me @colr6, i think we have it sussed now :)
