Jim mk2 Posted December 30, 2020 Report Posted December 30, 2020 Hi all looking to do a rear disc conversion on my Mk2. Who has done it and is it very hard. Looking at the Mk2 mania conversion kit. regards Jim
notenoughtime Posted December 30, 2020 Report Posted December 30, 2020 I originally done it on a mk1 cortina back in 1992 the only concern I had was the wheels didn’t fit that I wanted to use so check you have clearance you need to weld a bracket on the tunnel for the handbrake and use a mkv rs2000 handbrake cable as it’s shorter than a Sierra one you will also need the dog bone from handbrake to cable Sierra calipers I had to take 10mm off the mounting face to line the caliper with the disc I used Peugeot front discs and you have to take 2mm off the halfshaft flange outer diameter for the disc to fit over you just need some caliper brackets for the axle which most places sell
notenoughtime Posted December 30, 2020 Report Posted December 30, 2020 (edited) My mate did have a few axle brackets machined I’ll ask if he has any left Edited December 30, 2020 by notenoughtime
Jim mk2 Posted December 30, 2020 Author Report Posted December 30, 2020 Ok thanks. Has anyone used Mk2 mania kit?
notenoughtime Posted December 30, 2020 Report Posted December 30, 2020 What do you get as just looked on there website only found kit for £150 but I’m sure you will need to spend more with calipers pads etc
Jim mk2 Posted December 30, 2020 Author Report Posted December 30, 2020 Yeah they do the kit you have looked at and they also sell new rear calipers.
notenoughtime Posted December 30, 2020 Report Posted December 30, 2020 You can get rear calipers easy as just Sierra ones
colr6 Posted December 30, 2020 Report Posted December 30, 2020 9” brakes work just as well if not better, why go to all the hassle. 3
DT36 Posted December 30, 2020 Report Posted December 30, 2020 I'm with Col on this. If the drums are working well, I'd leave them on. I've had 3 RS2000S over the years and the 2 that had standard rear drums braked much better than the disc conversion I have now. My disc setup was already fitted to my current car when I bought it, along with a bias pedal box. I suppose I could convert it back to standard, but if I'm honest I'm just to lazy and can't be arsed 😂 1
Moderator Rally Pack 2000 Posted December 31, 2020 Moderator Report Posted December 31, 2020 2 hours ago, colr6 said: 9” brakes work just as well if not better, why go to all the hassle. 2 hours ago, dt36 said: I'm with Col on this. If the drums are working well, I'd leave them on. I've had 3 RS2000S over the years and the 2 that had standard rear drums braked much better than the disc conversion I have now. My disc setup was already fitted to my current car when I bought it, along with a bias pedal box. I suppose I could convert it back to standard, but if I'm honest I'm just to lazy and can't be arsed 😂 I also agree with this. Many get swept into the disk brake improvement upgrades because of the dinosaur concept of drums but with Escorts with so little braking being done at the rear, put your money into the front. You can even get quality new drum replacements for next to nothing as well these days. 1
notenoughtime Posted December 31, 2020 Report Posted December 31, 2020 9 hours ago, colr6 said: 9” brakes work just as well if not better, why go to all the hassle. I actually agree with col on this aswell! 1
Monza Posted December 31, 2020 Report Posted December 31, 2020 9” brakes work just as well if not better, why go to all the hassle.I went the same way...9in rs drums. All the parts are available new and not too expensive. Work very well too. [emoji106]Sent from my Hammer_Energy_18x9 using Tapatalk
meXEco Posted December 31, 2020 Report Posted December 31, 2020 Don't bother-complete waste of time and money.
Jim mk2 Posted December 31, 2020 Author Report Posted December 31, 2020 Ok what is needed for 9inch drums ? drums backing plates shoes Can my old shell cylinders and springs and clips be used ?
notenoughtime Posted December 31, 2020 Report Posted December 31, 2020 https://www.tickover.co.uk/shop/contents/en-uk/d377.html No backing plates there though
colr6 Posted December 31, 2020 Report Posted December 31, 2020 Think I’ve got a couple of 9” brake set ups
Monza Posted December 31, 2020 Report Posted December 31, 2020 Only part I couldn't get new were the back plates.... everything else from a motor factors place. Gave them an RS2000 reg from ebay and got all the parts except maybe the spring/clip set. Plenty of them on ebay tho [emoji106][emoji108]Sent from my Hammer_Energy_18x9 using Tapatalk 1
Johnny Boy Posted December 31, 2020 Report Posted December 31, 2020 Its a bugger you can't get anything from a motor factors without a reg number these days 🙄
notenoughtime Posted December 31, 2020 Report Posted December 31, 2020 (edited) 2 minutes ago, Johnny Boy said: Its a bugger you can't get anything from a motor factors without a reg number these days 🙄 What happened to when they looked in books lol or had an idea of what a set of points are Edited December 31, 2020 by notenoughtime
Johnny Boy Posted December 31, 2020 Report Posted December 31, 2020 Just now, notenoughtime said: What happened to when they looked in books lol or know the part number off the top of there heads.
Jim mk2 Posted December 31, 2020 Author Report Posted December 31, 2020 Might try motors tor with eBay reg
colr6 Posted December 31, 2020 Report Posted December 31, 2020 It’s like most things without a machine telling them they’re knackered. I spoke to a proper old skool parts kid when I wanted some strut insert for a RS2000 mk1, part number straight away ....no books or computer. These people ar3 a bit thin on the ground these days. 1
Johnny Boy Posted December 31, 2020 Report Posted December 31, 2020 There is a older guy at the motor factors I use in Eastbourne, old school , and very knowledgeable, oh that's a big word, I don't really ask the others any more 😳
Jim mk2 Posted December 31, 2020 Author Report Posted December 31, 2020 Would definitely buy new shoes , cylinders and spring s. Anyone got drums and back plates
