Posted (edited)
 Escort mk1 and Mk2 Stainless Speed Sensor Bracket is a durable and high-quality accessory designed for the front of the vehicle. Made from 3mm thick 316 stainless steel, this bracket ensures longevity and resistance to corrosion. Perfect for those looking to replace or upgrade their speed sensor mounting bracket , fits original steering arm bolts. this product provides a secure and reliable placement for the sensor to accurately measure the vehicle's speed and assist in proper transmission function. Ideal for car enthusiasts seeking quality components for their vehicle's drivetrain system. PLEASE NOTE , Mounting Bolts not Supplied.   contact MIKE  on 07969913777
£25.00 POSTAGE FREE
20260601_233838(1).thumb.jpg.871d6da36be4a20fc2fd7f92e09ea9a7.jpg20260601_231451.thumb.jpg.cbaf1afbb2d529a3684f7791684c2866.jpg20260601_231445.thumb.jpg.56051fcaeef5a2902c55633ce52c28a8.jpg20260601_231431.thumb.jpg.0c2ec5a5c2ed3a3d1d27176c0dd8c7ae.jpg20260601_231341.thumb.jpg.0484f0a4c1de55334f01435105c8ef99.jpg
Edited by mpdevelopments.uk
Posted (edited)
Is this AI generated? Why would any mk1 or mk2 owner require a speed sensor bracket for a non existant speed sensor ? ? ?  And the 1st picture shows said bracket fitted to a hub, with cap head screws that are welded to the bracket (well that ain't coming off!) but the whole thing - bracket, bolts and weld are Zinc Plated, how as the bolts are welded . . . . . . . . but why? - its stainless steel ! Looks like a con to me!
Edited by katana
Posted (edited)
no con. i purchased the zink one, then had them made in stainless steel, as there would be no rust issues, the weld on bolts, just allow you to remove steering arm  bracket without removing brake disc, for futher work.  the speed sensor bracket is req to read speed if using another form of dashboard, as i am running DASH2
ideal if your running a zetec in your mk1 or 2 with a mazda mx5 or rx7 gearbox, and aftermarket dash, as you will need this to run a speed sensor off front wheels.
If you need this it is good that it is available but I wouldn't say copying a bracket (small piece of metal with 3 holes) innovative work.
AI generated description seems to be quite common these days.
Great to see some innovative work that brings some value to owners who’d use this.
Thanks dave.
I purchased the zink one to fit to my project. But found the quality not as I'd expect. So I thought. Let make it from 316 stainless, so it would last. Then I thought maybe someone else would like this sensor bracket in stainless. Cheers
Sent from my SM-S711B using Tapatalk
If it improves owners who’d require this, then it’s a win. Innovative or not. Someone has taken the time to offer it.
Posted (edited)
Ok if you are using it just for speed into a digi dash, although I would also consider one of the inline speed sensors that go in the speedo cable.
What are you using for the trigger wheel?
Just make sure you dont use it for any for of traction control, I know a guy who did that on an F1 car at a test, driver was told to floor it and let the ECUs control it, the rears spun up but the fronts were not moving so the ECM put more power into the rear wheels till it hit the wall, not sure if there was more smoke from the tyres on the car or from the guy leaving the facility 🤣
Edited by GrahamU
Hi graham
It's only fitment is run on mk1 and mk2 escorts if you are running mx5 or rx6 gearboxes as they dont have any form of speedo cable fitment. As its controlled by the mazda ecu. And so need a speed sensor that picks up on front hub bolts as a way to determine speed once connected to a aftermarket dash. Hope this explains things.
Posted (edited)
Ok, reading a little on it I see they use the ABS for speed
But that is for the sensor only, how you mounting the reluctor ring
Edited by GrahamU
13 hours ago, mpdevelopments.uk said:
Mk1 or mk2 escort never had abs.
correct!!
I just re-read your previous responses and see you are using the wheel bolts as the reluctor, do you have a working example yet?
I assume you will be machining the heads of those studs to all be the same height otherwise you will get bad data from them
7 hours ago, GrahamU said:
correct!!
it picks up on a bolt head that hold hub to brake disc, and as they are all new wont be a problem.
  • 3 weeks later...
What I need is a way to run a MX5 / R8 Gearbox that has an electronic speedo sensor in the box, to run with my analogue Escort Sport dash 🤪
Any one got ant ideas ?
Posted (edited)
r8 gearbox has not got this function as its speedo is controlled by the ecu in mazda.  depending on your dash , might be able to connect speed sensor that picks up a signal by using  the bolts holding front disc to hub,  to calculate the speed, this is where that bracket will help. cheers
No bracket will help you with this. Escort Sport dash has a cable with rotating inners to the gearbox. Little plastic gear inside the box drives this cable. Maybe you could replace the Sport speedo with a similar looking dash from a Sierra which had an electronic speedo.
Its easy to convert a mechanical speedo drive to an electronic speedo , but not the other way round 😬
Its pretty common conversion, on older cars that have a mechanical speedo, but no one has got around the fix yet.
I'm running 2 MK2 Escorts with MK1 MX5 gearboxes, Thats easy as they have a mechanical speedo drive.
But the late rMK3  box , that are used in most conversions use electronic pick up
Posted (edited)
can i just clear up. you would only need this sort of speed sensor bracket. if in your mk1 or mk2 escorts you have fitted may be a zetec and A DIFFERENT GEARBOX, SUCH AS MK5 OR RX8 MAZDA that req a speed sensor to trigger the speedo on a aftermarket dash, such as,
AIM SOLO
HALTECH
STACK
RACE TECHNOLOGY  DASH2
AEM ELECTRONICS.
or similar req a electronic speed pickup.
