Vista mate,
How the fook do you transport an engine like that to the ship then drop it in?
With that one weighing 2300 tonnes :shock: Surly the ship would have to be built around it :?
Vista mate,
How on earth do you get an engine like that into a ship :shock:
Weighing 2300 how do you get it from the factory to the ship then drop it in? :?
Vista mate,
Nail on the head mate, the ship is built around it. and when the engine dies the ship is effectively dead too.
That said these things are built like brick shit houses, and they only rotate at about 120rpm so wear is minimal provided your oil and fuel husbandry is good (remember they run on heavy fuel oil not diesel). More often than not the ship is fit for scrap before the engine gives up.
As to machining them, the workshops and lathes that machine those cranks are enormous, and there aren't many manufacturers left in the world that build slow speed 2 stokes.
Going astern is interesting given that there is no gearbox and the propshaft is bolted straight to the flywheel, the cams change position and the starter turns the opposite direction rotating the whole engine backwards.
The company I work for make clutches for marine engines. Done loads of diesel and gas turbine ones and the clutches weigh in about 10 tons not including casing. Military ships are better as they have two diesels for slow speed maneuvers and two gas turbines for high speed work. Our clutches let you switch between them without stopping the boat :twisted:
SSS (synchro self shifting) clutches by any chance?
