Mine was very low mileage block hadnt been use much at all ,
Mines been taken out to 86mm with my crank it makes 1951cc
it's still got one more bore in the block and from what ive been told it will take 87.5 mm which would take me over the 2000cc think it works out at 2020cc ,
This all could be a rumour though! Wayne talks about it but are sure it exists? :mrgreen::thumbsup:
Hehehehehehe iam sure it does somewhere , cars not being built for qtr mile doubt i would get anywhere near your times mate , built for track and sprint :mrgreen:
Burton Power have quoted just over £1300 for the 2 litre xflow block. Should be available end of October early November.
so there doing it ?
sweet, im gonna start saving !
@ nick, ahhh wernt too sure on the block,
I had a reply back from Real Steel for the 2.0L Block
So time will tell what actually comes about.
Hi Dave!
I just got the price reply back.
They do not have the blocks until the end of October / start of November ......... £1,329.82 inc. v.a.t.
At least that is the price given at this point in time @ today's exchange rate.
delivery time would be 8 - 10 weeks.
Thanks!
Regards...
Mark in sales.
Tel: + 44(0) 1895 440505
Fax: + 44(0) 1895 422047
Spotted the typo, it was Real Steel that quoted me not Burton Power. :oops:
:lol: Never say never mate - I want to come and stand by the side of the track to hear it bark past! :ykt: I see your car featured in the WPE advert - very cool! 8)
Will big stroke steel cranks still require the block to be machined?
Yes you'll need to clear out a little for the conrods. The 84mm crank is a no-no in an L block - I did it but would seriously advise against it. It hits the water and the oil and takes a life times patience to fix.
I think there is more height in the bottom of a later CF block so there's not the same constraints.
I think 84mm is about enough stroke though, and a steel cam is adviseable as it needs reducing in 4 places.
What about in an AX block? will this still be getting close to the cam and the water ways?
you worry too much :mrgreen: . soooooooooon
I think there is more room around the water in the crossflow and AX blocks - Wayne at WPE has just done one (if we are to believe him :mrgreen: ) so I suspect he would have mentioned it if it was a problem. The cam still needs notching.
I have heard of 82mm being done in L blocks without a problem with the water - the cam still needs notching.
looks like i will have to cut a hole in my bonnet if these new 2.0L blocks are coming with that extra piece of cast iron off the bottom of the main caps!!! lol :lol:
doh....obviously that bit will go in a modified sump...stoop :pointandlaugh:
  • 4 months later...
Is this not the remanufactured block then? I thought they were going to be thick 'uns? Like the AX block - it's says re-manufactured - I'm amazed anyone would make a 711M standard thickness -unless it's for some rules :?
I think they are being re manufactured for Formula Ford 1600 and there fore are to original specifications
I see! Poo! :mrgreen::thumbsup:
