Jeff HPE Motorsport Posted November 5, 2007 Report Posted November 5, 2007 Toby, we have allways been impressed with your car & especially that engine m8, we are secrectly gutted, that you have gone that much quicker than what you had done before, 2 tenths, & as much as James would probably like to carry on with the crossflow, I think that little 1700 has a tiny little bit more in it, but not 2tenths, so keep on going m8. Us Harris` love more or less all Fords & especially me who thinks that there is nothing else out there but Fords, I & other members of the Harris` have had a lot of mk1 cortinas over the years, but never anything as quick as yours, so massive to ya. Once again a big well done m8. Jeff Harris..
SmokeEm Posted November 5, 2007 Report Posted November 5, 2007 I saw the 1st 2 runs & it was awesome. As you say, perfect weather for racing
H.P.E harry Posted November 5, 2007 Report Posted November 5, 2007 Well done toby mate, awesome car and engine. Big thumbs up.
MK2Ed Posted November 5, 2007 Report Posted November 5, 2007 Mk2Ed misses out again I remember racing against u at the '07 CF show where I was sufficiently beaten... So will be coming back for more next season - well done on the new time though
slidelong Posted November 5, 2007 Report Posted November 5, 2007 Hi All As you can see this is my first post, although i have been a lurker for a while. I think this is worthy of a first post just to say a big congratulations to TOBY That is some achievement from a pre cross flow in a MK1 Cortina.. i would love to see your engine in an escort to see how much quicker it would then run!!! Once again well done mate..
DarrenM Posted November 5, 2007 Report Posted November 5, 2007 Fantastic time there Toby, just for those who don't know (ie me!) what's the basic spec of the engine?
Fiesta Steve Posted November 5, 2007 Report Posted November 5, 2007 what's the basic spec of the engine? HOT !!
Toby Posted November 5, 2007 Report Posted November 5, 2007 what's the basic spec of the engine? HOT !! MILD Only 2 chillies on the packet!! Easiest way to see the spec is in readers rides, when I say easiest, easiest for me!! Best bit is the Spinal Tap link under the photo of the dash board on page 5! (Normal ones go to 7! You'll see )
Toby Posted November 5, 2007 Report Posted November 5, 2007 well done mate, superb Thanks Baz - I was gutted for you! The amount of times I have been to Pod and had problems! I know exactly how you felt! At least you got a whole 1/4 in! Being pushed off after 2 ft is really embarrassing! It's the days when it goes like it did for me yesterday that make it all worth while! Next year Rodders........!! ( that kind of works )
DarrenM Posted November 6, 2007 Report Posted November 6, 2007 Rough spec. Pre-crossflow built on an L block. 3D machined head for perfect chamber replication accross the cylinders. RS200 BDT pistons (85.6mm) with the tops machined off to loose the bowls. Stroker Dug Kiddie crank. Arrow Rods. Race steel cam. Thin stem followers! 180 + Bhp (Sanspeeds rollers showed 201bhp but I think that reads a little high) Tran X diff for strength with large shafts. Recently having boken so many pinto gear boxes I have made every cog in the box as straight cut gears from alloy tool steel. This meant I could choose my ratios. Whilst I was at it I made it a dog box. There you go I thought you must be using an AX Block to get the capacity up. I will want to tune my Twin Cam soon and am wondering how to get the capacity up. Is an AX block an option with the Twin Cam's head or is a Stroked crank the way to go?
Toby Posted November 6, 2007 Report Posted November 6, 2007 I thought you must be using an AX Block to get the capacity up. I will want to tune my Twin Cam soon and am wondering how to get the capacity up. Is an AX block an option with the Twin Cam's head or is a Stroked crank the way to go? Thanks mate. No I am using the L block AX block is an option, you just have to do some thinking and sums with regards to stroke, rod lengths and piston compression height. My engine was overstroked and gave me all sorts of problems with the oil and water galleries. I even had to turn the cam down in 4 places to allow the crank to turn, although you just run a jack shaft dont you. I think 82mm stroke is the max but don't quote me on that! This route is fraut with problems especially if you are doing it to an expensive block. If you can speak to Nick Stagg engines in Chipping Sodbury he is a VERY good twink man, although don't know if he's given up. Best of luck let me know if want any more info. Why are you after capacity? Think about any class you MIGHT want to run in before starting. It could affect the value of your finished engine.
DarrenM Posted November 7, 2007 Report Posted November 7, 2007 I wanted capacity to gain Torque. As a cheaper alternative to a stroked crank or an AX block I understand there is a 711M block conversion. I have a 1600GT engine with T18 casting no. Taking on board your comments then perhaps I should use that block with the Twink head and not mess with the L block:huh:
Toby Posted November 7, 2007 Report Posted November 7, 2007 Cc's are good for torque L block will probably take a bigger bore than the 711 but dont assume - measure. I have ground away an old vernier caliper so I can get down the water galleries to measure the cylinder wall thinknesses. you can depth mic to the front bore wall thru the water pump hole and thru the back core plug too. Not less than a 0.085" wall I was told. 711 block will be stronger as it has the square main caps as standard. but wont take the bore an L block will. A big bore is good for breathing and rev's and long stroke is good for torque, as you know I was greedy and went for both! The flat top pistons gave me more options than you have. You will have to look for shorter rods if you go looking for stroke - maybe the 125E rod - got me thinking now!! You? It's against the thinking to have a short Rod - it messes up the -stroke to rod ratio. You pays your money and you takes your choices!!
DarrenM Posted November 8, 2007 Report Posted November 8, 2007 The Escort engine is like the MK2 Cortina one which (should ) have the square main caps and the 125E rods as standard. I will strip mine down over the winter and see what I already have as the previous owner had it rebuilt but that was 22 years ago!
kevmk2 Posted November 8, 2007 Report Posted November 8, 2007 Well done Toby,wish i could of been there but i was in a much warmer place for 2 weeks
Nick Mexi-cos Posted November 9, 2007 Report Posted November 9, 2007 Bit late but well done toby bet that sounded sweet , lets just see what the other pushrod boys can do the bar has been raised yet again top work fella
Toby Posted November 9, 2007 Report Posted November 9, 2007 Thanks Nick Better late than never I think the crossflow in James Harris' Escy is coming out to be sold as they want to run a Pinto as a show piece in it for HPE sales reasons. TBH I am glad I am not clean out of ideas yet so I am going to carry on racing myself as I think we probably all are anyway! I hate golf but I bet it's just the same as chasing a handicap - and I mean that in a PC way!
