at the front ?
increase castor
Thanks, but :oops: Can you explain to someone who thinks castors are under the living room couch :oops:
the castor angle is the point that a line drawn through the top mount and lower ball joint and lands infront or behind of the wheel contact patch.
the steeper the angle the more self centering the wheel will have and the more straight line stability.
Guest MK1gaz
My mates 180 bhp Harris pinto goes 13.8 secs @ 97 mph on 175 mm wide street tyres with NO weight saving at all so full trim , steel panels , glass windows , etc . So you get a 180 bhp zetec and go beat it then . :D
Ok mate... I'll see him at the lights... because I have a 180bhp Zetec in my Anglia.
And its fully trimmed and its got glass all round and a steel boot and bonnet and doors and the tyres are filled with air not helium.... :roll:
But if I beat his time then you will be whining about my 185mm tyres and my diff and my gearbox and then oh well... you've got all that Milton suspension on your car.... blah blah blah blah blah.
If you can get in the 13's without gas , slicks , turbos , superchargers and taking the half car to bits to save weight then far play to you and your zetec engine . It won't foooookin happen in my lifetime though !!!!!!! :lol::lol::lol:
Guest MK1gaz
Well it just cracks me up when all the traders selling the modern stuff harp on about the pintos being rubbish :roll: . They must be flipping blind as well as stupid to have not noticed all the proper fast ones out there kicking arse every meet . I'm not imaging it then am i ? You know , the 2 x mk1 escorts running 11's without gas , turbos , 2 foot wide tubbed rear ends , space frames , ladder bars , etc , etc . :wink:
This is the thing Gaz .. the only one doing any slating of any engine here is you..yes you ..
Others just state facts as you do sometime,,, you shoot yourself in the head let alone in the foot by saying the 1/4 mile is a true measure of perfomance and then go and say that the pintos run 11's against cars with more gip and more power... so how is the 1/4 a accurate measure .
What the 1/4 shows isthe difference between a good set up and a bad one .. someone with huge grip and power should beat the car with less grip and less power, but as we have seen ... lots of engines that have the same power run different times ... and here i am talking about pintos. They are probably the most common engine to be thrown down the strip and the times range all over the place.
The other thing to consider and this is why i keep talking about you and your fixation on the 1/4's is that the vast majority of people out there will spend maybe 3 miles a year on the 1/4 mile and 3000 miles on the road .. and on the road drivability makes a good car, the torque of a good pinto makes a nice car, but on the same hand the modern engines prouduce nice drives too.. and generally cost less bhp for bhp than the pinto.
well all my mates 180+ bhp pintos all drive nice on the road , all tick over nice , all last ages and all didn't cost a fortune either . They also have no grip , no fancy drag racing set ups , only leaf springs and normal uprated rear shocks . Yet they really do shift in a race as proven by the quarter mile time and terminal speed at santa pod etc . There's no point having an expensive to fit and get working zetec or duratec if a pinto is as fast is there ? You'll only beat one if you spend a fortune that's all i'm trying to point out . It's fine fitting a standard zetec / duratec etc as they will go ok but when/if you tune it later on your not gaining anything over the 1970's motors :thumbsup:
sooo gaz what should i do? i have a choice of engines, st170 or 2.1 pinto, both will be running nos :lol: i will also have two shells a mk1 and a mk2, which engine in which car? also one will be stripped out and one would be full interior including kids seats for my daily drive, which combination would you use for each type of car? :lol::lol::wink:
sooo gaz what should i do? i have a choice of engines, st170 or 2.1 pinto, both will be running nos i will also have two shells a mk1 and a mk2, which engine in which car? also one will be stripped out and one would be full interior including kids seats for my daily drive, which combination would you use for each type of car?
It makes perfect sense to me. Which shell is heaviest (might be worth getting hold of a four door here, bit more ballast)? ok, now put all the trim back in it. make sure its the heaviest option, none of this lightweight popular plus cardboard and vinyl here please, we want to see velour and deep pile carpet!!!! Stick on a set of budget 155/13's, all tires grip the same anyway so anymore than that is a waste. If you really must have wide low profile tyres then 175/70/13's are just about acceptable.
Now bolt in the pinto and go clean up against all the top fuellers :twisted:
Guest MK1gaz
Aaaaaah now let me see mr twinkle :mrgreen: If using a mk1 or mk2 escort for a daily runner then i would use the mk2 because the bodywork is cheaper to replace when the "school run mums" crash into it down at the school + at Tescos !!!!!!! :shock: . Put interior in the mk2 daily smoker and the standard st170 motor if you must though i'd sell it and get 2 pintos myself !!!!!!! :lol::lol::lol: . Put the pinto in the race mk1 without interior though , has anyone ever seen a fast zetec yet then because we haven't !!!!! :wink:
Just one example of where the Modern Ford engines beat the Pinto in identical vehicals ...
The important wording here is " the next rung up"
http://www.sports2000-srcc.com/proseries/engine.cfm
And when reading that ... remember that includes everything to run the engine from the dry sump ... to the ECU for the TB's ... just add up those parts for a Pinto... and then add the work to get the pinto to that power..
Seriously these Duratec cars are lapping the pintos in the real world... And also notice the engine is standard ... nothing internally is changed , no cams no head work no overbores to get the capacity up. its as it has been pulled out of the mondeo... standard ... £200 salvage or £1275 for a brand spanking new engine
So for 4-5 k you have a fuel injected standard engine, which produce 197bhp 164ft/lb ... and to fit it in an escort .... a set of mounts, a bellhousing and a water rail from RETROFORD ... thats an engine thats good for 100,000 miles or more as its stanard, not stressed .. no thin walls, no lumpy cams (130ft/lb @2000rpm)
And this post ... well its just to show the other side of the coin..
Now can someone add this up for me ..
Pinto engine totally rebuilt to produce itro 190bhp
inlet manifold
throttle bodies.....
linkage...............(these 3 can be replaced with new carbs and a£300 dizzy)
management......
drysump (excluding tank and lines)
Steel flywheel
uprated clutch
dyno run and ready to go
Just as a comparison .. just for fun :D
inlet manifold
management......
Steel flywheel
uprated clutch
My Pinto engine is up around there, but yet to be fully set up on the RR (cheaper than dyno I must add) Spec differences are: -
It has 45's not TB,
Not dry sump
RR not dyno (still to be done)
I reckon it owes me in excess of £4.5k by the time all the niff naff and trivia are accounted for. And it's just been done so I have the gaping hole in my wallet to prove it
Guest MK1gaz
You can build a 180-200+ bhp pinto for less than a standard duratec install will cost and IT WILL BE MUCH FASTER than a standard duratec by miles . If however you use your Escort for mini-cabbing etc then by all means use a standard modern £5000 engine install with throttle bodies etc to ferry your fares from A to B . :lol::lol::lol:
I can only liken Gaz to a Jehovahs Witness... no matter what anyone says, no matter how abusive, he just smiles and says... 'Can I interest you in a Pinto..... the pinto loves you... we are all the pintos children and the Great Pinto sent his son 16v Pinto to save us all so one day a duratec may live... praise be the pinto.... all smile to the quarter mile'
Well Gaz.... even if we all think you are a complete front bum... jesus loves you....
:lol::lol::lol::lol::lol::lol::lol::lol::lol:
FPMSL :thumbsup:
:lol: :lol: :lol:
So that's why my Mum's knelt in front of my Capri
every Sunday mornin :shock:
:lol: :lol: :lol:
is your mum fit? :lol:
What utter tish and piffle, my install is a Pinto and did cost nearly £5k to get to the level of spec it is. Besides a standard Duratec install doesn't cost £5k and by the time you've spent the difference on uprating the Duratec you're way of of the pintos league
Damn, I'm NOT going to be drawn into this!
:gary::gary:
Bored now
:zzzz:
Guest MK1gaz
It depends on who or which way you build an engine to the desired power level that determines the cost of it . You can build a 180 bhp pinto cheap with 2.8 V6 pistons and standard rods etc or you can do it with steel rods and forged pistons etc . Both the same power but one costs twice as much and is stronger . A standard duratec install needs lots of expensive conversion parts which unless you can make them yourself you'll have to buy for big money . Then it doesn't have a dizzy so you really need full engine management which alone is £2500 . It really needs a dry sump set up as well so the cost is very high for the puny power it makes as standard . Plus it's made of chocolate so will explode after 5 mins !!!!!!! :shock::thumbsup:
1Inlet manifold + fasteners
4Throttle bodies, 45mm parallel + fasteners, O-rings
1Throttle body lever kit
1Fuel rail, dash 6 JIC fittings (exch. o.e. fuel rail)
4Fuel injector, high flow
1Fuel pressure regulator, dash 6 JIC fittings
1ECU, MBE 967E (Sports 2000 sealed unit)
1Throttle pot.
1Barrometric press. sensor
1Air temperature sensor
1Engine wiring harness
1Water pump drive kit
1Dry sump kit, incl. 3-stage pump, al. sump pan, pulley?s and hose fittings
1Steel flywheel, light weight, integral ring gear
6Flywheel bolts, race spec.
1Crank pulley/damper bolt
1Crank spigot brg.
1Clutch cover, 8.5in., uprated
1Clutch plate 8.5in., 1in. x 23 spline, uprated
6Clutch cover bolts
1Exhaust manifold gasket
6Exhaust manifold nuts
1EGR valve blanking plate + fasteners
1Blanking plug kit
All for Total kit price.................£2762.00 + vat
Add a brand new engine
To order your base engine (2007 price £1,275):-from Mountune
And you have a dyno run 197bhp engine that needs a water rail, and mounts and bellhousing.. and thats it ...
That is one of the funniest things Ive ever read :lol::lol:
